Question about Belling Kitchen Ranges
Electrical issue.The stove will not turn on and the whole front screen is off.
  • Belling Master
  • 3,463 Answers
I feel you should check that you have got power to the appliance, Check fuse and or circuit breaker.
Posted on Dec 15, 2008
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
I have a frigidaire PGLEF385CB1 range, after an electrical strom the oven stopped working. before I even call a repairman. what is the most expensive thing it could be and what is likely to be the issue?
Was your stove on during the storm have you checked the electriclal breaker to the stove? I cant imagine the whole stove going out perhaps this unit has a common power module
Apr 09, 2012 | Frigidaire Kitchen Ranges
The whole range quit working -
First thing check your breaker. if the breaker is good then unplug the stove and remove the back cover and check the power cord connection where it first connects. Check for any loose connections there. Also if your main power cord is plugged in behind the stove you could check the box for loose connections. Be sure to turn the breaker off first. If you are not sure about handling the electrical outlet then I would call someone who is.
Aug 08, 2011 | Ovens
None of the elements work, stove top or oven, stovetop light 'surface heating' will come on but nothing heats. Oven light on panel doesn't turn on but light in oven is off unless both dials are on or a...
Remove the panel on the top of the back of the stove - check for grease residue on connectors plugged into circuit board - clean connectors and circuit board with electrical contact cleaner - reassemble and test for correct operation. The oven vent at the rear of stove sometimes leaks grease filled vapors into the area of the control circuit board.causing bad or intermittent electrical connections to oven temp sensors and front controls on the oven.
Dec 22, 2017 | Kitchen Ranges
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
244 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
