Question about Samsung DynaFlat TX-P3064W 30" TV
Strange picture issues
Hi, I have a Samsung TX-P3064W which has started to have a problem with the picture. The picture color changes on its own, getting darker when there are darker colors on the screen and then lightening up when lighter colors are on the screen. When you're watching it it looks like someone is playing with the contrast. Ever heard of this? Any suggestions? Thanks.
  • Anonymous Mar 22, 2008
    how do i check the transformer?
  • 38 Answers
Check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Posted on Mar 18, 2007
Gray picture for all RGB inputs
Check the connections. If connections to RGB has conected wrong, this type of fault will occur. Follow the color codes of wire ends both at tV and DVD.
May 27, 2012 | Samsung DynaFlat TX-P3064W 30" TV
Color Temp Change
you have a picture tube problem, or bad capacitors in the screen circuit. I'm afraid not a job for the end user. A repair shop should be able to assist you in this repair. good Luck
Jun 11, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Wont turn on ,bulb ok what next
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Any buzzing,humming,or high pitch sounds? If you do it could be an issue with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
Apr 07, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Cant use TV as Computer display
If you can disable the blue screen via the tv menu you might see something happening behind that blue ,you might be able to figure it out from there, also try to connect as directly as possible (tv/computer) even if you have to physically move one or the other, that way you can eliminate possible problems. good luck
Nov 03, 2009 | Samsung DynaFlat TX-P3064W 30" TV
HAVE ROUND RAINBOW WHILE TV IS ON
then need to be gone service. i think colour circle may have changed.
Oct 10, 2009 | Samsung DynaFlat TX-P3064W 30" TV
Gray picture
This sounds like you have the contrast setting too high, go to your menu and find the contrast settings, and adjust to your requirement. As for the words being blurry, this could be because your tv is HD ready, and unless you view a High Definition channel then the picture will be a liitle blurred.
Hope this is of some help?
Sep 16, 2008 | Samsung DynaFlat TX-P3064W 30" TV
My tv cant turn on
make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
1 www.partstore.com
2 www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
May 26, 2008 | Samsung DynaFlat TX-P3064W 30" TV
Picture is Psychodelic....
I HAVE A SAMSUNG HD TV MODEL TX-P3064W AND I TURN IT ON AND GOT ALL OF THE COLORS IN PSYCHODELIC MODE. I NEED TO KNOW IF THIS IS AN EASY AND CHEAP FIX?
Dec 16, 2007 | Samsung DynaFlat TX-P3064W 30" TV
No picture, beeping sound.
it is due to your VIF OR TUNER section has stopped working due to no supply or some parts gone defective. some times it is due to signal absent from the source from you are getting. good luck.
Oct 06, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Samsung DynaFlat TX-P3064W 30" TV Logo
138 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
