Question about Sony KP-57WS500 57" Rear Projection Television
'' A colored 'splotch' on tv screen following brown out
..once the power returned after going out several of my electrnics were blown out...my sony grand wega 42 tv now has a growing colored splotch that sometimes looks like a bullseye target and other times a cloud on the screen,only when tunrned on, the splothc is most visisble on certain color backrounds, green i think is the worst
SOURCE: sony KDF55XS955, 5X GREEN THEN 6X RED BLINKS, SCREEN BLACK
5 blinking lights IS the lamp board, part # 1-468-927-12
Posted on Mar 04, 2009
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
  • 668 Answers
SOURCE: sony xbr 60 grand wega color problem.
It sounds like to me you have a bad Optical Block. It is a expensive repair and you may want to call Sony at 1800-222-SONY and see if the would assist you in repairs. Due to the age of it, they would probably only cover a partial amount of the repair.
Hope this helps,
Skyassoc
Posted on Jul 25, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
SOURCE: Sony Wega 42" LCD HDTV
My tv is flashing 3 times and i have tightened the bulb housing like 5 times and still green light comes on then immediatly off with three red blinks then a few seconds 3 red blinks again
Posted on Feb 22, 2010
Color splotches
I had same problem, or should I say I still have it, slowly getting worse, and I had replaced the Y board which would be logical based on description of what board controls, but it didn't help. I found out it is the plasma screen, and not worth replacing, so I put up with it until picture is all full of shadows, then will part it out. Last time I had issues with capacitors a few years ago, I spent $400. on several boards, including Y board trying to isolate problem, that is how I learned it didn't help the shadows creeping in after warming up. Live with it or buy a new TV is what I am doing.
Sep 08, 2014 | Dell W4200 42 in. HD-Ready Plasma...
My Insignia NS LCD 37 will power up but the screen is gray and there is an even lighter gray bar going up and down but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | Insignia NS-LCD37 37 in. LCD TV
Samsung ua40d6400 power
- Flickering screen
- Dim screen
- Slow start
Check the cables, connectors and connections.
Mar 12, 2014 | Computers & Internet
I have blue splotches appearing on the screen . I was told it was the color engine. Is that true.
d_rick_schmi,
That is true. I have a tip at http://www.fixya.com/support/r7851924-sony_projector_yellow_or_blue_dots which will explain the problem and give you several solutions as well as how to get a discounted new unit from Sony.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Blue/Yellow Splotches on screen
It will be 12 appliance years old in October. Not much justification for trying to repair it.
Mar 23, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
Kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Apr 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Color splotch when TV is powered on, then TV powers down automatically
Good Day;
It is very common for this model from what you spoke. If you handy return to me, Big Irish, and I will continue to help you.
99.9 % of the time of what you stated it sounds like a shorted CRT, picture tube. I have seen hundreds.
First, call the manufacture and complain about your concern and ask them for a CONCESSION because your tube has gone out.
2.If that does not work ; call a factory authorized service dealer to confirm problem and get an estimate, then return ti #1.
Good Luck, Day, Big Irish. I hope I helped.
Jun 15, 2008 | Sony KP-51WS510 51" Rear Projection...
No blue colors projected on screen
Only a few causes for this problem. "Splotches" are usually caused by dust in the light engine which can sometimes be blown out using compressed air. Pink picture is caused by either data or burnt lcd card. Procedure for data is: put tv to ch. 3 and turn power off. simultaneously press input and power on set for three seconds to access service menu. Be very careful not to change settings other than what needs changed. These adjustments are changed using directional arrows. Navigate to "memory init" then hold (r) arrow button for 5 seconds. You will know if it worked. Then exit and/or turn set off. Please let me know if this is successful as I have additional info you may need. Good luck, Russmann.
Jun 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony KP-57WS500 57" Rear Projection Television Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
