I bought a new digital flat screen TV and also a new rabbit ear antenna to replace my old TV. The digital reception is beautiful, but it swtutters A LOT! I have relocated the TV and the Antenna to near a window, but the problem persists. My old TV with built in rabbit ears was generally fine, though sometimes the reception was poor on some channels. Should I move things differently, give up and return everything, buy a different antenna?
SOURCE: Magnavox TB 100 MW9
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Posted on Jun 24, 2008
  • 374 Answers
SOURCE: how to connect converter box
Okay if I don't know exactly what your situation is but it sounds as if your TV is not cable ready but instead has terminal screws for spade connectors to connect an Over The Air antenna. If this is the case thay mak a transformer that converts the signal from the coax attached at one end to that of spade connectors at the opposite end. If you do not have this set up but yellow/ white or red/yellow/ white inputs you could purchase an RF modulator and a set of composite cables to accomplish the same goal.
Hope this helps you and if you would please provide me with feedback on my solution by ranking it please. Thank you and if you need further assistance please post a comment to this solution.
Posted on Sep 11, 2008
eagle338
  • 4889 Answers
SOURCE: I have a digital TV
You will probably need to get a digital HDTV box from your service provider. This would be the easiest fix to resolve this issue. You can get a box for as low as 35$ and its definitely worth it.
Posted on Dec 04, 2008
  • 28 Answers
SOURCE: I have rabbit ear antennas. can i hook up the converter box to s
yes and your picture will be much better.
Posted on Jan 09, 2009
  • 360 Answers
SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Posted on Jan 29, 2009
I have an emerson tv and I am trying to install philips antenna on it and It will only give me two channels is that it?
The new digital TV often requires new outside antennas as old rabbit ear indoor are often insufficient for the UHF type signals of the new system.
Feb 06, 2011 | Philips Televison & Video
No matter what antenna i use i can't get reception
are you tryin to get over the air tv signals, like with rabbit ears? if you are, you will need a digital converter. if you are using cable from the cable company, it is a tv issue.
you may not need the converter, but it is only in newer tvs (within the past 1-2 years old.)
Dec 10, 2010 | Curtis Televison & Video
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Digital broadcast
While this TV is HD ready, it only contains an NTSC tuner. If you have an antenna or rabbit ears for reception, you will require a converter.
This unit IS NOT digital broadcast ready.
Dan
Jan 21, 2009 | Proscan 19LA25Q 19 in. LCD Television
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Nov 02, 2008 | Televison & Video
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
