Question about Canon T90 35mm SLR Camera
T90 shutter I just bought a used T90 without batteries, put in new batteries, set up a shot, and the 1/2 click worked fine and gave me the readings and than when I pushed the shutter completely down, nothing. checked my settings and tried again, still nothing, even tried the timer, the 2 second and the 10 second, worked but still did not take the picture. Any ideas?? Tim
Hi Tim, I had the same problem , I took it to get it repaired & was told that it needed a new shutter solinoid , the repair cost £90 5years ago, you are probably looking at around £140+ today. mine has gone again & I am reluctant to spend that sort of money on it again. If you manage to get it repaired & there are periods of time when you wont be useing it take it out periodicly & just run the shutter a few times, it helps to stop it sticking. Good luck with whatever you decide to do . regards dave.preece@ukonline.co.uk
Posted on Apr 27, 2007
SOURCE:
I have a Nikon F601 and I put a 400 iso film recently and I sort of didnt know how to load it on properly so I pressed the shutter release button as I loaded it twice when youre only suppose to press it...
Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
Jul 21, 2011 | Nikon Photography
DSC T90 digital cam While taking pictures of any small movement, the picture blurs or shakes. Please give me solution to fix this problem
To remove the blur from photos, you need to be in a place where there is enough light to have a fast shutter speed. Using the camera indoors without the flash on will usually result in blurry photos.
Try using the flash.
Holding the camera with two hands or even better, on a tripod, will help too.
Happy shooting!
Mar 06, 2011 | Sony Cyber-shot DSC-T90 Digital Camera
Zoom wont work
Reset the camera setting , if the problem still remains than its software problem . due to T90 has no physically zoom out.
Apr 21, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
Sony t90 got wet with a water splash during swimming now i cant take pics and there's "E:62:02" Constantly flashing.can u pls help me?
Open the battery compartment and remove the batterys and the memory card. Completly dry the camera as best you can without further damaging it. Let it set open up like this for about 5 to 7 days. Recharge the battery and reinsert the battery and memory card. If you have to reinsert the battery to recharge the battery, do so. If it still doesn't work, contact the factory for a repair estimate.
Nov 13, 2009 | Sony Cyber-shot DSC-T90 Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
I just loaded up my old T90 after 4yrs of non use. All was well, the display showed mode, shutter speed etc then when I took the first shot I got HELP in the viewfinder and the three EEEs on the lcd. I...
Lin & Daniel,
I had the same problem w/ my T90 after years of not using it. But, the T90 is not dubbed the Tank for nothing. The shutter curtains stucked/stacked because of unuse, especially if you hadn't used it for years.
Here's what i've done to revived it:
I set the shutter speed Tv 500 in Low then hit the carpeted floor while pressing the release button.
Try it my friends and let me know.
http://cyberman9.multiply.com
Feb 27, 2009 | Canon T90 35mm SLR Camera
Film not exposing.
Ok, well are you using a lens that is compatible with the auto setting? Are the batteries new and fresh in the camera? If you are not sure about the lens, then what you can do is too look at the inside of the box of the film you are using (Kodak) has a setting and exposure guide printed on the box. Try using the required exposure for the light that you are in... say for bright sun try f 16 at 1/125th of a second. That setting is for Kodak Royal Gold 100. That is right off the Kodak exposure guide, which you can find on the web here
http://www.kodak.com/global/en/consumer/products/techInfo/e41/index.shtml#exposure
I'd stick to Kodak film if possible. Try that out, and if no dice, then take the camera to a repair shop and have it looked over. good luck!
Dec 19, 2008 | Pentax ME Super 35mm SLR Camera
Canon T90
It kind of depends on what exactly the problem is. If the problem is that the speeds are off, then that can likely be remedied without any new parts. It needs a clean, lube and adjust. If its due to the shutter curtains being worn and they need replacing, then there is a possibility that it uses the same curtain as another Canon model and parts can be had new for that model. Worse comes to worse, a parts body can be used for the repair.
Watch the cost of this stuff though. T90s on the used market are selling pretty cheap, so it might make more sense to buy another used and keep yours for parts.
Dec 01, 2008 | Canon T90 35mm SLR Camera
Canon T90 35mm SLR Camera Logo
365 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Norman Worley
Are you a Canon Photography Expert? Answer questions, earn points and help others
