HP 2015 Printer not printing as a shared printer
I have to uninstall printer and change usb ports to reinstall as a local shared printer - works a few days and quits until reinstall done again - print jobs just evaporate
  • ronmur Dec 16, 2008
    Thanx for idea - has happened several times - prints fine for a few days then quits - nothing in queue
  • 66 Answers
Hi Ronmur,
Few checks...
1. Is there sufficient diskspace for to queue print jobs?
2. There a corrupted print job that is holding the queue. Find the which application on which computer sent the print job. Send it again to see if it holds up the print queue.
Posted on Dec 16, 2008
  • sam88kid Dec 17, 2008
    Need to narrow down the problem - printer or computer.
    3. Connect up printer to another computer to see if you get the same problem.
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Print jobs get stuck in the queue
OK - all the answer posts on HP sites, Experts Exchange and MS have been a joke to this problem so far. HP 10xx series LaserJet printers do not work (well) in a shared environment. I have found two solutions to this problem. If you really don't understand shares/printing/services/firewall exceptions - don't bother trying this - buy a networked printer when the toner runs out of the HP10xx.
If you want to spend a few hours or about $100 for a print server/NAS device, read on... I HAVE an HP1022 shared on a Windows XP Pro SP3 machine serving as a print server to a Vista laptop, a Windows 7 desktop and a Mac-Mini running OS X 10.6.x. ALL are working.
1. Buy a network print server device (or a NAS device with an included print server - I picked up a Buffalo LS-CHL 1TB and it worked out of the box. I AM NOT ENDORSING BUFFALO NAS servers, they get horrible reviews and you may end up having the same problem down the road due to the NAS device) In this case, your print clients (Win7, Vista, XP, MacOS X) can use a traditional SMB Windows client to print or the BETTER solution is to use the print services for Unix client that comes with Windows but is not installed by default. Both clients work, you may have fewer problems down the road using the Unix (LPR) client. See http://www.alexfalkenberg.com/2009/10/06/linkstation-windows-printing-problem-solved/ This is an excellent article on the Buffalo - BUT THE SOLUTION works in a native windows environment as well.
2. Build on the idea from number 1 above and INSTALL the LPDSVC (friendly name TCP/IP print services) on the machine with the printer LOCALLY attached through USB. You will also have to open up some firewall ports on the machine you are using as a print server if you have one running... I used a program exception (C:\WINDOWS\system32\tcpsvcs.exe) but you could lock this down to 1 TCP port if you wish - I think TCP 515 but you'd better check on this one...) Share the printer as normal. Next install the "Print Services for Unix" CLIENT on the machines you want to connect to the printer remotely from. When you connect to the printer share from the clients, select a LOCAL port, create a NEW PORT, select LPR, use the hostname or the IP of your machine acting as a print server and the NAME OF THE SHARE as the queue. (I don't like to have spaces in my share names, so I used HPLaserJet when I set up the share and description.) You will HAVE TO INSTALL THE RIGHT Printer driver locally on each client. This might be easiest just plugging in the printer with a USB cable since the HP printer driver is an installer as well and wants it to be connected locally unless you can extract the driver...)
Sorry I can't give more details than this. If you don't get the jist of what I am saying above. Don't try it. Give up and call the plumber.
Feb 09, 2010 | HP Hewlett Packard LaserJet 1022 Printer
My printer light is on but i cant print anything?Help
If you are connected via the USB cable, the connection may be lost (or the setup which is particular to the actual USB plug itself). Try deleting the printer and reinstalling it. Don't change USB ports after the printer is installed by the way. Also we had problems with this when the printer was networked (shared) and the auto sense was on - after another person printed the local box would seize up. Try not having the printer auto sense its presence so that 2 printers show up in the network neighbourhood. Of course check that the cables are installed right and try changing USB ports.
Jan 31, 2010 | Brother HL-2040 Laser Printer
I cannot connect the hp psc 2175 to my computer
Check your usb cable works fine.
check your computer usb ports are works fine.
Try with usb prots 1 by 1.
Also uninstall driver then reinstall.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP PSC 2175 All-In-One InkJet Printer
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
Jun 22, 2008 | HP Photosmart C7280 Printer
Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
May 02, 2008 | HP LaserJet P2015dn Printer
The scanner wouldn't work on a HP L7680 All In One Printer. I downloaded the newest Hp drivers. The scanner started working, but then I couldn't print from Quickbooks(bookkeeping). I uninstalled the...
Hi ,
go to printers in the control pannel.
click on add a printer
in the wizard click on local printer but un check search for the connected printer, under ports check the usb virtual port on which the printer is connected .. under drivers choose HP as manifacturer and under drivers use DESKJET 550C in case of windows XP or DESKJET 990C in case of vista operating system .. try to print is should print .. issue resolved on near about 100 cases
wishing u good luck
Mar 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
Not printing
Try changing the USB cable then if doesn't work uninstall printer the unplug. Install drivers first then plug in the machine.
Try this hope it works for you
Thanks J
Sep 26, 2007 | HP LaserJet P2015dn Printer
147 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
