Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Projection bulb needs to be replaced
Could you give any tips on reploacing this bulb? Where is bulb located? How to get to it?
The bulb is behind a removable panel on the right side of the T.V. Remove the two Phillips screws, then remove panel. You should see a black square thing, this has two more Phillips screws on it, by the way this is the bulb holder. Remove the two screws and pull on the silver handle, and that should be it. The bulb you need can be found here, http://lamps-dlp.com/ProductDetail.asp?PartNumber=6912V00006C&A=G&B=6912 hope that helps you.
Posted on Jan 16, 2009
  • 4 Answers
Removal/installation is easy. go to http://guides.fixyourdlp.com/guides.php I purchased my bulb through them and it was an original Phillips bulb at the cheapest price I could find anywhere... http://www.discount-merchant.com/
Posted on Jun 25, 2009
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
How to replace bulb?
Either under the front long cover--or on the left side. Most HIt LCD projos use a P22H 120 watt bulb, get a phillips bulb and you will be happy. Ebay sells these all over the place.
Apr 28, 2014 | Hitachi 60FX32B 60" Rear Projection...
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
My Sony Wega KDF-55XS955 TV keeps getting a blank screen every 4-5 minutes. I've been told I need to replace a bulb; however, cannot figure out where to locate the bad bulb. Any assistance would be...
julian1390,
That could certainly be your problem. If the unit has not had the lamp changed in the last 3 years it ceratinly would not hurt to do that. Even if this is not the problem you will have a replacement lamp for the time in future when the lamp does go. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will help you do this.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 16, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
How do i change the bulb
Bulb TVs are very big. In most cases the TV will give a warning that alerts you it's time to change the bulb. Do not touch the glass part of the bulb, as oil from your hands will reduce the life span of your bulb. Replacing the bulb is a simple process that will take a few minutes. Here is how to do it.
Step 1: Read User Manual Make sure that you have your user manual with you when working on your TV. Most electrical appliances will have guides on how to deal with replacements of parts and where to get the replacements and what specifications to look for. Read the user manual in depth before attempting the project of replacing the bulb. Step 2: Disconnect Power When working with any electrical appliance, always switch off and disconnect the power. Electrical shocks can cause injury or even death. Step 3: Open Bulb Door At the back of the TV there will be a bulb door which will usually be near the power cord, depending on the make of the TV. Once you locate the door, proceed to open either by sliding it open or unscrewing it as may be required. Step 4: Remove and Replace Bulb Once the door is open, unscrew the bulb assembly and remove it. You can then remove the bulb from its compartment. Bring out the new bulb. Hold up the groove on top of the new bulb and align with the groove pocket on the inside of the TV, then proceed to slide the new bulb into place. Step 5: Replace Bulb Assembly Once the bulb is securely held in place, return the bulb assembly to its position and screw it back. Make sure not to tighten it too much but have the screws just firmly in place. Step 6: Close Bulb Door Once you are finished, you can close the bulb door after making sure there are no tools or screws left inside. Having such items inside the TV could cause a short circuit. Your door needs to be closed for the TV to operate. Tips: Remember to allow the old bulb to cool before you remove it. It will usually heat up to very high temperatures that could cause some serious damage. Most TV bulbs will warn you to replace your bulb while about a hundred hours are left on the old bulb. This duration is meant to give you time to get the replacement bulb and fit it. Finally, if you do not feel confident in doing the replacement yourself, get a professional to do it for you. They might charge you a fee, but it will be cheaper than the cost of damage caused by a poor fit.
Take care in solving the fault
May 12, 2011 | Zenith R57W46 57" Rear Projection...
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
RED LIGHT CAME ON WAS TOLD NEEDED NEW LAMP STAUS LIGHT NEED TO REPLACE IT HOW MANY SCREWS IN BACK DO I NEED TO REMOVE TO GET TO LAMP AND APPROXIMATELY HOW LONG SHOULD PUTTING NEW LMP IN TAKE AND DO U HAVE...
You must locate your bulb (usually from the front lower cover of your tv). Some tvs the bulbs are reached from the back. Bulb replacement is about a 30 min job (if you're fast at taking screws out).
Here is a video of putting your NEW bulb in the OLD housing:
Just locate your old bulb, watch the video and you'll be running again in no time!
Thank you and please rate!
Apr 11, 2011 | Mitsubishi WD-60735 Projection Television
I replaced bulb on LG tv but replace bulb light is still on
Its the fuse the is located beside the bulb housing. You need to replace this fuse. Its used almost like a timer. The TV detects a new fuse and blows it at this time it resets the bulb life.
Jul 05, 2010 | LG RU-60SZ30 60" Rear Projection...
Bulbs not working
the big converence ics like SK----- as they go bad your covergence with shift and shift and become unjustable..need to replace them. the bulbs? if your messing with CRTS dont or even try turning the yokes. sometimes it takes me hours and days to put all back right what the customer did....alot of times if you call my shop and said you were working on it Id tell you to call somebody else. good luck
Aug 16, 2007 | Samsung HCM422W 42" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
330 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
