Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Projection My repair man gave me a new black box, (presuiming I could install it i guess) I can figure out all the wires, Im just not sure how to remove the larger colored wires from the base of the bulb. The new focus box has bare wires on the larger wires. I just dont know if those just pull out or what at the base of the bulbs. Someone help!!
  • Dawn Price Mar 18, 2007
    I found the tab that releases those wires, now i cant figure out how to release the main power wire (the white one).
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Maybe it is soldered..John
Posted on Sep 11, 2007
1988 rodeo high beam relay location
no country stated, no that DOES make this hard.
lighting does very by country, (DOT laws ......)
no symptoms posted. sigh
very old car.
why does wiki show 89 as first year.?
why is 88 missing in alldata.com
my guess, is 88 is build date? and not official mfg year date.
sold under 10 different names
my on line page shows, 1991 rodeo (usa)
head light relay , with 4 pins and the red-blue wire.
ok location.
the fsm im views shows a man with hood open
and removing the fuse box clear cover. and on said cover is the words. head lights, over the Relay spot.
lost the cover? or even look under the hood.?
there is a cab fuse box too with same markings.
the car came new, with the operators guide (sure lost) and has all that there. all fuses and relays.
quote.
Sales of the three-door began in the United States during the second quarter of 1989 under the Isuzu Amigo name
http://en.wikipedia.org/wiki/Isuzu_Wizard
see why not saying country , makes this car so hard.... link above.
Jul 31, 2014 | Isuzu Rodeo Cars & Trucks
MSD with Procomp Dist no spark on ONLY cyl 4
The cap is cracked or the wire has a break in it mobte the wire to anothet plug and see if it does it there
Apr 15, 2014 | 1984 Buick Regal
How do i test the control board on minn kota maxxum 80lb?
My guess is you either have a brushwire against the housing or the leads are on the wrong terminal. the red/black goes on the same as the lower brushwire and the black goes on the same as the upper brushwire. The motor should have a 60A breaker, assuming you have 6ga wire. If wire is smaller than 6ga, the breaker should be downsized. To test the control board, check the voltage in and voltage out. Voltage out should vary as you turn the dial.
Oct 12, 2012 | Minn Kota Boating
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
How do I install throttle position sensor on 2001 oldsmobile alero
I have a 2004 Alero ( similar procedure in your model as well ) and I just figured out today and replaced my throttle position sensor. I'm not sure what the black plastic "box" is called that is above the throttle assembly...but I had to remove that to get to the throttle position sensor underneath. If you can locate the two wires that control the throttle assembly...then the throttle position sensor is on the other side of the throttle assembly. I had to remove the large tube that went from the air filter to the black plastic "box" above the throttle assembly. Also disconnected anything else connected to that black plastic "box". Then pulled that "box" up and right there on the left side of the throttle assembly was the throttle assembly sensor. Here is a web page with a picture that helped me figure out where it was :-
http://en.wikipedia.org/wiki/Throttle_position_sensor
http://www.ehow.com/how_4590680_replace-throttle-body-oldsmobile-alero.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 10, 2010 | Oldsmobile Alero Cars & Trucks
My lemax house had it's volume/( black box) elictrical smashed . how To I repair it. Can you help me?
Glue doesnt do much. if your lemax house over-heats the glue previously applied will simply tear off. I have recently smashed my volume box as well and im afraid i have no advice =(. I had to replace with a brand new one because the repair were even more expensive than a new house. im sorry.
Oct 02, 2009 | Lemax Toys
Air conditioning unit not running but fan keeps running even though thermostat is turned to off, auto, and temp set to highest position 90degrees. 3 amp fuse keeps blowing on the circuit board in the...
if the fuse is blowing then this is generally indicative of a short in the low voltage wiring, isolate the wires on the thermostat and the unit ends, use an ohmmeter to verify that there is no path for continuity with no wires touching, if there is then you must pull new t-stat wire to the thermostat, (a guess would be that the green and red are shorted, by the symtoms you gave.
Jul 20, 2009 | Heating & Cooling
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
