Question about 2wire (1000-400108-001) Router
I AM RUNNING VISTA CAN I GET UPDATED SOFTWARE FOR MY 2WIRE PORTAL
I UPGRADED TO VISTA AND NOW I CANT GET MY 2WIRE PORTAL SOFTWARE TO INSTALL. IS THERE AN UPGRADE OR NEW SOFTWARE AVAILABLE ?
  • singlejudy Jan 01, 2009
    1000 SW (Model) for 2wire,Connects fine, intermittently the Broadband Link goes ORANGE and keeps me off Internet
  • Rakesh  Kumar
    Rakesh Kumar May 11, 2010
    what is the 2 wire ??
    is it a router or modem
    if yes whats the model number?
  • 7 Answers
I UPGRADED TO VISTA AND NOW I CANT GET MY 2WIRE PORTAL SOFTWARE TO INSTALL. IS THERE AN UPGRADE OR NEW SOFTWARE AVAILABLE ? ► there is no need to install the CD if ur trying to connect using an ethernet cable to the 2wire. If ur attempting a wireless connexn, u shud configure the wireless set up.
1000 SW (Model) for 2wire,Connects fine, intermittently the Broadband Link goes ORANGE and keeps me off Internet ► this is a possible line problem. Try plugging ur 2wire's phone cable directly to the phone/wall jack removing the filter or splitter in the process. Then see if the problem reoccurs. If it DOES NOT, replace ur filter with a new one. If it DOES reoccur or if it is already connected to the phone/wall jack directly, contact ur Internet service provider.
keep me posted on these...
Posted on Jan 27, 2009
Cant find cd to set up computer and hotsync phone to
Here you can find all information related to your Palm Treo 700 W:
http://kb.palm.com/wps/portal/kb/na/treo/700w/verizon/home/page_en.html
If you want to hotsync your phone you need to download the Microsoft Active Sync software from this site:
ActiveSync Software
for Windows XP icon_activesync.png Download Updater 1.22 (Windows Installer) for Treo 700w/wx for Verizon downloads-item-update.png Update your phone Update Windows Mobile
Device Center for Vista icon_activesync.png Learn more
Hope it helped.
Nov 19, 2009 | Palm Treo 700w Smartphone
Using 2wire 1800hg Home Portal. Have successfully connected with PC Port Adaptors using the existing telephone line. No problems. Then purchased a laptop w/ Vista installed. 2wire setup CD causes error...
Listen, you do not need that CD! This is already configured. That cd is for other types of troublesome operating systems that just cannot seem to get is DNS settings right such as windows XP. The cd is for XP only you do not need this with vista.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 18, 2009 | 2wire 1800HG Router (RG1800HG00)
I recently upgraded from my 2wire DSL to Uverse. My older laptop with the 2wire card and the home portal fins the new network but only runs at 11 mbps. Where my other laptop with the newer 2wire software...
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Jun 29, 2009 | 2wire HomePortal® 1800HW Router...
Cannot update the windows defender and malware protection
You can go to the following webiste
http://www.microsoft.com/security/portal/
Select your operating system as 32 bit on the right handside box and download and install the updates. Make sure to disable your third party firewall if any
Thanks
proton
Apr 04, 2009 | Microsoft Windows Vista Ultimate Upgrade...
2wire adapter plugged in pc running vista software, cuts off part
I would suggest increasing the wireless power on your router or change the wireless channel.
Feb 26, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Feb 07, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Navigator for pixma mp500
his product can be used with Windows Vista.
  • To use it with Windows Vista, install the software for Windows Vista.
  • The Windows XP software for your product cannot be used under Windows Vista.
  • Easy-WebPrint and PhotoRecord do not support Windows Vista.
Upgrading from Windows XP to Windows Vista :
Before upgrading your OS from Windows XP to Windows Vista, delete / uninstall all the Windows XP software first; then, upgrade the OS to Windows Vista and install Vista software.
If you have already upgraded your computer's OS to Windows Vista :
Delete / uninstall Windows XP software before installing Windows Vista software.
You can download from
Driverscollection.com
Mar 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
Ubuntu 7.04 linux-install on Dell Laptop C610 doesn't see adapter!
Ubuntu is up to 8.04. They made a lot of improvements to the network interface. You should upgrade. Go to "system-administration-software sources-" click on the updates tab and then select normal updates under release upgrade in the updates tab. Ubuntu will then tell you that you have updates. State the update manager and click on the option to upgrade to the next version up. If you aren't sure how to do this write me back and I will help you.
Oct 17, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
IPod shuffle Second Gen problem
Apple recommends that iTunes customers using Windows Vista upgrade to iTunes 7.2 or later. If you are using an iPod with iTunes on Windows Vista, please review the important information in Knowledge Base document
Ejecting iPod using Windows Explorer on Windows Vista may corrupt iPod
Issue
Some customers may see the following message when connecting an iPod to iTunes 7.2 or later on a computer running Windows Vista.
Solution
Microsoft has released an update for Windows Vista that addresses a situation where ejecting iPod from Windows Explorer or by using the "Safely Remove Hardware" feature in Windows Vista could corrupt your iPod. Apple recommends Windows Vista customers who own an iPod install this software update. For information on how to install this Microsoft hot fix, refer to the "Update your software" section below. Tip: iPod can always be ejected safely by choosing Eject iPod from the Controls menu within iTunes.
Microsoft has made this Update for Windows Vista (KB936824) available via Windows Update as well as a separate download package. To download this update via Windows Update follow the steps below:
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, select Check for updates in the Security section. If the Control Panel is in Classic view, open Windows Update.
  3. Click the View available updates link and be sure that Update for Windows Vista (KB936824) is checked.
  4. Click Install.
Sep 15, 2007 | Apple iPod shuffle Second Gen. Silver (1...
2wire (1000-400108-001) Router Logo
184 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
