Question about Reddy Heating & Cooling
Only runs for 15 seconds or so.
This unit sat around for years until it was given to me. I changed the sparkplug type ignitor and fuel, put some additive into the tank incase there was any water I missed, cleaned the injector, air filters, and fuel filter. When it's plugged in it runs for about 15 seconds. So I disconnected the photo sensor and it acts the same way. Does this mean the photo sensor is bad or could it be the breaker?
  • 232 Answers
Does the 94 lincoln tc exec come with the pats system
if its been sat for years the fuel filter has probably deteriorated, and its now in the fuel lines. there is a number of parts that need changing before you start an engine that has not been run in a long time. fuel drained, fuel filter changed, oil and filter changed. fuel goes off after a year or 2. oil can turn to sludge in the sump. and block the oil pump. this can also affect the oil pressure sensor.
Apr 14, 2018 | Lincoln Cars & Trucks
2010 Buell Blast starts but stalls after about 15 seconds
From the sounds of that I would say FIRST get a new battery!
The stalling problem sounds to me like the carb needs to be cleaned!
May 30, 2012 | 2010 Buell Blast
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
The breaker button keeps popping on my heater. 14yrs old. stored indoors. was in use for 1/2 hr then sat for an hour. went to start no fire just noise then pop and smoke. took off top cover got sloppy...
There is a good possibility that the motor is not running at full speed. You should attempt to turn the fan and check for stiffness in rotation. The breaker is sensing a high current draw and is perfroming normally. If you find the motor is stiff use a parifin based lubricant. The "Zoom-Spout" Oiler is the most common oil that we use and can be purchased for around $3.00. There is an internal tube inside the oiler you can pull out / extend that is great for reaching into tight places. Make sure to lubrcate both ends of the motor.
The other thing to check is to see if the ignitor is shorted. Read resistance from the wire to the probe surface. If you read resistance the ignitor is internally shorted.
The owners manual is here:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000007880.pdf
Parts can be found here: (ignitor on this page)
http://www.reddyparts.com
I doubt that the fuel filter is causing your symptom but... if the ignitor remains on due to a lack of fuel flow it may be tripping the breaker. The ignitor should be on for less than 10 seconds.
Fuel and Air Filters are here:
http://www.reddyparts.com/filter_kits.htm
Lstly the ignitor transformer may have shorted since you said the unit is 14 years old it probably has this transformer installed:
http://www.reddyparts.com/transformer.jpg
This transformer is no longer available and has been replaced by this rather pricey kit:
http://www.cart32hosting.com/cgi-bin/cart32.exe/REDDYPARTS-store?catid=14&prodid=24&Theme=Demo NOTE They recommend Photocell replacement should you have to change this transformer.
Service Manual can be found here:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
That should just about cover it. If you need more assistance just repsond here and I will help you.
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Dec 18, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
90 yj only 70k on it sat for 2 years. 4.2 carb, ran one day now hard start, runs for 15 min. then dies. cant restart unless kept in start position. not ign. switch, fuel pump, cap, rotor, wires, plugs, or...
Check the fuel for a presence of water. I'm sure there was a recall notice on the gasket on top of the fuel tank where the sending unit mounts. My YJ sat for a year and had water in the tank from this leaking. Drain and drop the tank, replace the gasket, and reinstall.
Oct 09, 2010 | 1990 Jeep Wrangler
Bike sat for awhile, runs but doesnt idle very good. cuts out
I would remove and clean the sparkplugs - sounds like one may be fouled.
Aug 18, 2009 | 1994 Yamaha FZR 600
Idles good, dies when i put it in gear
I had a very similar problem except I would have to throttle my truck just to keep it running. It wouldn't even idle. If I were you check the spray pattern on your fuel injectors. It should look like a nice misty cone. Youy dont want lage drips of fuel, you want a mist. Also cut into your fuel line to test your fuel pressure. It should be around 9-13 psi. My truck had 3psi. I then replaced the fuel pump and the problem was solved. Hope this works for you.
Jul 04, 2009 | 1988 Chevrolet C1500
Only runs for 15 seconds.
Testing a photocell is a simple procedure
How to test a photocell
Dec 15, 2008 | Heating & Cooling
Heating & Cooling Logo
258 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Superior Maintenance
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
