Question about Dynex 19 in. LCD Flat-Panel HDTV
HOW DO YOU SET UP MORE THAN ONE FAVORITE CABLE CHANNEL ?
When i try to add more favorite cable channels i only get to channel 30 and i have about 90 cable channels available
  • 36 Answers
Dear Customer
Sir/Madam the memory of the content(TV) is to store about only thirty channels so u can not able to store more than that,if in case you want clarifications just get linked with below site which may help you sometimes.
http://www.northjerseymall.com/Mall/CommonPages/contactv3.asp
Thank you
Posted on Dec 17, 2008
Program favorites on a digital stream converter box with the remote.
The last time I saved favorite channels, I had to go to my "On Demand" screen. Then, put it on the channel you want to add as a favorite. The icon I had was a "heart" and you scroll to the heart icon and click. It should add that channel to your favorites. An easy way might be when you're watching that channel, to hit "favorite" on your remote as the gentleman above suggested. I believe it depends on your Cable Provider and the type of remote you have. You can always call their technical support # and ask. They'd be happy to walk you through it.
Jan 01, 2015 | Televison & Video
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
Aug 13, 2009 | Samsung 50 in. Plasma TV
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
Unable to get cable channels past channel 33.
Your problem is likely not your TV. It's due to the signal being provided by your cable company. I suggest that you contact the cable service provider which you are using and advise them of the problem.
Mar 18, 2017 | Spectra KT2313 Combo
Only receive 2 channels.
Can you punch in the channel numbers directly to go to the channels, but just not tune to them with the Channel Up/Down buttons?
If so then try tapping the favorite button on the remote until the screen shows "favorite mode off". This mode likes to stay [or perhaps turn] on when you scan for channels, but scanning clears everything in the favorite list except for the channel you are on when you start the scan (so it seems), thus leaving only one or two channels showing up. (This happens whenever I re-scan for digitals.)
To pick out favorite channels, go into the channel menu in the tv menu and with "Favorite: Analog" or "Digital" highlighted near the top, hit OK on the remote to toggle favorite status.
Nov 28, 2007 | Mintek DTV-263 26 in. TV/DVD Combo
Dynex 19 in. LCD Flat-Panel HDTV Logo
126 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
