Question about SAMTRON 55V 15" CRT Monitor
Monitor problem- colour changes to white appearance to yellow appearance
Dear sir, normally my computer is working fine but few days back there is problem starts before me as all white colour appearance changes to yellow? i am unable to find out, why is it coming so? Earlier the color changes back to normal after 25-30 minutes of working, but now its appearance remains same yellow which looks so bad. please help me to resolve this, and to get rid of this problem as soon as possible..? thanks in advance... mohit
COLOUR MONITER BASE COLOUR IC SOLDING AND BASE SOLDING OR CHEAK DATA CABLE
Posted on Apr 07, 2007
SOURCE:
Monitor changed to yellow colour.... what is the problem...?
Monitors mix the 3 "primary" colours, in various proportions, to produce all other colours.
Mix equal parts of all 3 colours, and you get WHITE.
Mix equal parts of only 2 colours, and you get YELLOW.
So, either:
1. your computer's video-card is not sending the 3rd colour;
2. your video-cable between the computer and the monitor is broken, and is not transmitting the 3rd colour;
3. your video-cable is not TIGHTLY connected at each end;
4. the electronics inside the monitor that SHOULD be producing the 3rd colour have failed.
Try connecting the monitor to a different computer, with the same video-cable. If it works correctly, your video-card is the problem.
Try connecting the monitor with a different video-cable, to see if replacing the cable fixes the problem.
Try connecting the monitor to a different computer, with a different video-cable. If it still is incorrect, then the monitor needs repair/replacement.
Jan 14, 2010 | Computers & Internet
My samtron monitor turned into yellow colour
Sir this usually happens because of Serial cable getting damaged I have been through same problem have took my monitor every where but was no use in the end I thought of changin monitor serial cable and now its working great. So I would recommed you to change serial cable.
Nov 11, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Stripes appear on monitor at bootup
I decided to change the background of my desktop and it works.
May 14, 2009 | Gateway FPD1760 17" LCD Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Greenish screen
sometimes speaker magnets or any metallic device can cause this disturbance in this type of monitor. also, if you are using dvi, i would reset all video driver settings to default. this may correct this green tint you are seeing as well. reinstalling the monitor software could have a positive affect.
Feb 05, 2009 | Dell E196FP 19" LCD Monitor
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
134 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
