Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
Replacing the guard on the LS1214 Sliding mitre saw
After changing the blade on this saw i never took much notice about the way the safety guard came off, now i am in a fix as to how to replace it??? any help appreciated
  • a191 Dec 16, 2008
    disassembled the thisng. didn't realise i could replace the guard by just undoing the bolt to release the guard .now when i put it all back together as the diagram in the manual suggests, it is catching on something and not working right.
    there is a bar that is supposed to catch on the guard and push it up when you push the saw down and i think this is the problem. it is bent? is is supposed to be??? thanks
  • David Ford
    David Ford May 11, 2010
    Did you take it off in one piece or completely disassemble?
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
Posted on Jan 03, 2009
  • 10 Answers
SOURCE: Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Posted on Oct 26, 2009
  • 178 Answers
SOURCE: One of my apprent's took
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=469
Here is a link for your parts diagram and owners manual.
I hope this helps!
Posted on Nov 24, 2010
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
How do I replace the blade on a Pro-pulse 10" compound mitre saw. I can't get the safety guard off to reach the blade bolt.
There are several you tube videos for different brands. You may find one similar to yours.
Feb 14, 2018 | Blade Saws
Replacing blade guard on a 1700W sliding mitre saw
There is an upper (fixed) blade guard and a lower (moving) blade guard which has the added complication of being connected to a linkage or mechanism to swivel the guard away from the workpiece as it approaches the cut.
Mostly careful inspection, once the blade has been removed, will show removal of the guards to be a faily intuitive process. It is inevitable some makes of saw will be more complex and in the absence of official detailed instructions, it will mean a process of removing clips and screws until the part falls off and then remembering what you did so you can put it back together with no parts left over.
Jun 12, 2016 | Saws
HOW DO I CHANGE THE BLADE ON A 36-070C MITRE SAW
Not sure about the Delta. I've had both a Craftsman and a Dewalt. On both of those, the pivoting plastic guard pivots on a plate on the side of the metal guard. The plate isnt easy to see. You rotate the plastic guard all the way open and you see the edge of the plate held in place by a screw. Remove the screw and the plastic guard and the hub along with the plate it's mounted on can lift up an half inch or so--far enough to get the blade screw off the arbor.
There's a push button somewhere that locks the blade from turning so you can turn the screw in the center of the arbor with a wrench.
Sep 16, 2014 | Saws
Need to replace the blade on the saw. mastercraft 10" mitre saw. i've managed to loosen it but can't seem to get the blade out of the machine to put the new one in. what am i not doing?
Lifting the safety guard maybe? The blade will not pass through the opening with the guard down (it's one of the purposes of the guard).
Jun 13, 2011 | Garden
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
255 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
