Question about Frigidaire AEQ7000ES Dryer
Motor will run , drum will not turn
Is the belt broken, if so can i replace this belt myself ?also do you have a repir manual for this model with a parts brake down and part numbers? ( FRIGIDAIRIE MODEL # AEQ7000ES1 )
    Master:
  • 479 Answers
Http://homeappliance.manualsonline.com/manuals/mfg/frigidaire/frigidaire_product_list.html?s=gg314159 just click the above link and select the model number and download.
Posted on Dec 15, 2008
  • 13,433 Answers
Heres how to replace a dryer belt
http://repair2000.com/wpoolbelt.htm
Hi, I've got a Kenmore model 110.70052991 and the drum won't rotate. It will intermittently. I have just replaced the belt and it still won't spin consistently. Could it be the
are u able to spin the drum manually? do u hear any sounds? squeaking? scraping? smell anything? the rollers (spinners lol) usually make funny noises when they go out and may still turn but roughly. Bad bearings may be an issue here? However if the motor has bad windings it may not have enough power to run (turn) drum consistantly, u can remove the drum and belt and housing and run the motor by itself and see if it turns and runs easily. with no pressure or weight added? Then add drum and belt, once the drum is added and it stops or runs half hazardly its ur motor ? In some cases the tensioner the belt sits on ( near the motor) can be damaged and cause similar problems , lastly u did add the belt correctly?
Dec 23, 2014 | Kenmore Dryers
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
The drum of my washer does not spin freely. When I manually spin the drum, I found myself having to push it along to turn on one side. Also I found pieces of white plastic on my laundry? Please advise...
This drum is driven by motor which is coupled with a belt that connects the drum and the motor,the is a possibility of a broken belt,or the motor is stack, may be the motor is not receiving power for the motor to be driven to drive the drum.
To access this you need to open the screws at the back of the washer,the plastic pieces is a sign of some broken parts in the washer,if you find that it's the belt that slept off the puller place it back and test but unplug the washer from power before doing all this.
May 18, 2010 | Whirlpool GHW9100L Front Load Washer
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Sep 25, 2009 | Maytag Dryers
Drum does not turn
Here are a few things to check. If you don't feel comfortable performing these check, please have a repair person come in and check it.
* Broken belt. Open dryer and see if belt is still wrapped around the drum. Pull on the belt to make sure it's not just hanging there. Inspect belt condition. Do not apply spray adhesive in this case: replace the belt. If belt is broken, look for contributing causes for failure such as worn drum rollers, damaged felt kit, or stiff idler roller.
* Motor burned out. Remove belt from motor pulley and start dryer. If motor runs but is noisy and motor is unable to turn the drum when the drum belt is threaded back on the motor pulley, then replace the motor.
* Thermal fuse is open. Run continuity test.
Hope this helps.
Sep 10, 2009 | Kenmore 63942 Dryer
The drum will not turn, but I can manually turn the drum. The motor does run with the door closed.
Check the belt. It may have broken. Replacements are readily available from any appliance parts supply house. Just have your make and model number with you when you go.
Best regards,
--W/D--
Aug 10, 2009 | Maytag Dryers
Asko superior 7004 heats, but drum will not rotate.
Sounds like the belt is broken. See if there is a trouble door in the back so you can inspect the belt. If it is broken, get a new one from the dealer, and ask for instructions for replacement. If you can only get the belt, google your unit for more help.
May 07, 2009 | Asko Dryers
Looks like a belt broke for the drum.
Not knowing what model you have. To reinstall most belts you must first remove the front of the dryer. Once the drum is exposed, then you can retrack the belt around the drum. You'll see where the other one passed. then you will have to place the belt around the tensioner and pulley. If you still have the manual, it should show you exactly what to do. Of course, shut the power off before making any repairs. But first i would take the back off and look at the motor down below. You can see the belt from this angle as well and it's a lot easier than taking the front off. Good luck.
Apr 20, 2009 | Dryers
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
Dryers Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
