Question about Linksys Wireless-G Broadband Router
Unable to connect wireless
I am using Window Vista and trying to connect wireless. I have wirless-g 2.4 ghz 54mps. Please help me to setup. Thank you
  • 1 more comment
  • Anonymous Dec 17, 2008
    yes i can get to internet with router via wired :) but unable to go to wireless.
  • laura81881 Dec 23, 2008
    Having same problem..Im not much on technical though...just know the basics..Hope someone can help us!!
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    Can you get online through the router via wired connection?
    This is important before we go wireless on your network.
  • 51 Answers
Since you are unable to go via wireless, follow these steps:
1) Access your router configuration pages by typing in 192.168.1.1 into your web browser.
2) Click the tab that says Wireless.
3) Make sure the wireless broadcast option is enabled. If it isn't, enable it and select save settings.
4) Set up the wireless network through your Vista PC by going to Start > Network.
5) At the top of the window, select add a wireless device. Follow the onscreen instructions to add your Linksys Wireless Access Point.
6) Once added, right click on Wireless-G Router (name varies) and select configure. Follow the onscreen instructions to configure your router. (You can find your router pin by following steps 1-2 and selecting Wi-Fi Protected Set up.)
7) Once completed, attempt to connect to the internet via wireless router.
Posted on Dec 24, 2008
  • Bryan Mildort Dec 24, 2008
    For step 1: The username field is left blank, and the password is admin.
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
Sep 04, 2009 | Dell Inspiron 6400 Notebook
No internet connection,
hi
if you have already configure your router and it was working following thing could have happen
1) you have lost connection to internet ...go to your router setup page under status make sure you have connection
2) once you have your router connected re-boot your laptop or pc or renew your wirless connection
good luck
Jun 12, 2009 | Linksys WRT54G2 Wireless Router
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Wirless netgare router setup
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
May 22, 2009 | NetGear WGR614 54Mbps Wireless Router...
I WANT TO SETUP MY ROUTER TO WIRLESS
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go to START and find RUN, then type in CMD and hit ENTER, should throw up a black box (Dos window) you will type IPCONFIG and it should give you an adapter gateway ip address like 192.168.0.1 or something like that, from there close out that box and launch internet explorer or firefox or netscape or whatever browser you use. Type in the ip address where you would normally type www.google.com. Hit ENTER, this will interface you with the router. It might be password protected. Usually the username and password are both the word admin. If not look at the bottom of router for password. Look for wireless tab once in router and select network type as wep. Look for the key that the router automatically generates. This will be your wep key. Now your wireless connection will be secure. Hope this helps...Tennis123
May 15, 2009 | Sitecom (WL -004) Wireless Adapter
Linksys Wireless-G 2.4 GHZ two computers distribution of Mbps
unfortunately wireless is slower. i wouldn't worry though as 100mps is what windows always says but this itself is not accurate as your isp is probably even less than 18 mbps.
Apr 05, 2009 | Linksys WET54G 2.4 GHz 802.11g Wireless-G...
Wirless router
Try This link:
http://www.retrevo.com/support/Netgear-WGT624-Wireless-Routers-manual/id/420dj078/t/2/
Oct 11, 2008 | NetGear WGT624 Wireless Router
Cant connect to cable
Hi Snuggles,
Make sure your networking permissons are setup properly, on the Vista. Since it varies with what version Vista you have, try this link.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
Great help site for Vista. Click on the Network tab, follow the info to setup your networking, and if you are still having issues, got to the troubleshooting. Please make sure you doing your setup with a cable, too, not over the wireless.
Good luck
Jan 10, 2008 | NetGear DG834G Router
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Blitzz BWU 713 Wirless G
Here is a link to get the drivers for the BWU 713 wireless adapter: http://list.driverguide.com/list/company2072/index.html This site requires you to register for free in order to download the file. After you install it, go to START, CONTROL PANEL, NETWORK CONNECTIONS. You will reach a window that shows some connections with computer icons. Right-click on the wireless connection and select 'view available networks'. In the next window that pops up (in the left pane) click refresh network list. If there are any wireless routers in your surroundings, they will show in this same window on the right. These drivers are for windows 9x and xp. They might not work for vista. If your OS is vista, please let me know so I can try to locate a vista driver. Hope this works for you. Lolita
May 15, 2007 | Blitzz Technology Wireless G BWU713...
Linksys Wireless-G Broadband Router Logo
162 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
