Question about Coby DVD-224 DVD Player
Coby 626 DVD Player Remote Not Working
I have a Coby DVD player, Model DVD-626, and the remote all of the sudden has stopped responding. I did change batteries but it still will not respond. I tried programming a learning remote I have but it also would not accept a signal from the remote. I didn't drop the remote or anything so don't know why all of the sudden it would stop working. Any help would be greatly appreciated.
  • 1 more comment
  • Bob Smith Apr 01, 2007
    I have fixed my remote! What I did was first I took a Q-tip and dunked it in alcohol and then cleaned the battery contacts. At first that seemed to work but then the remote stopped working again. So I looked at the remote's battery contacts again and noticed that one of them had some bad corrosion on it. I then took a very small piece of fine sandpaper and carefully sanded off the corrision. It worked and now a week later my remote is still working.
  • Anonymous May 26, 2008
    I had the same problem with the 514 -- it must be a glitch in the manufacturing! I will try the sandpaper!
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
Posted on Jun 05, 2008
SOURCE:
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
Remote does nothing and I have replaced batteries. How do I get it to respond?
I have a coby DVD player too.My remote didn't etheir.I fix mine by take a sharp knife pride it open and take it aparts,take some Q tips dipping it with some rubbing alchachol clean the PCB and take a rag with some WD40 rust cleaner clean the - + batteries connections and than i used a soldering iron resolders the - + batteries connections and wait like 20 mins put in brand new batteries.The remote work again.If u can do all that 80-90% the remote will be working again 10% wouldn't because the CPU chip itself it shorted and dead.Or try website like Remotes.com to buy an orginal remote for the replacement.
Jan 11, 2011 | Coby DVD-514 DVD Player
My remote for my coby dvd player stopped working and i am trying to program my rca universal remote to use it. my actual remote that came with my dvd player is not working. i switch batteries because i...
One or more button of the remote may be sticky and touching together.
If this happened, the remote will not work.
Remove the batteries and press all of the buttons at least 2 times.
This will free up all the buttons.
Install batteries and try remote.
Jun 22, 2010 | Coby DVD-224 DVD Player
Remote control not functioning properly
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
It sounds like the remote needs to be replaced. Below is the procedure you would follow to obtain a replacement remote from COBY.
To obtain a replacement part from COBY, you must follow these instructions:
Please send:
1. A money order made out to COBY Electronics in the amount of $6.00 (FOR EACH PART ORDERED! -- TFDVD batteries cost $18.00)
2. A note with your full name, phone number, and return address.
3. A note detailing the model number of the device/unit and the part being requested.
4. If you're requesting a replacement remote please write the numbers found on the back of the remote on the note mentioned above.
We strongly suggest you either send the above requirements via certified mail OR with delivery confirmation which is available from the post office. And please hold on to your money order receipt/stub.
COBY will not make return shipments to a P.O. Box. For shipping to international addresses, actual freight will be charged. Please mail the above requirements to:
Customer Service
COBY Electronics Corp.
56-65 Rust Street
Maspeth, NY 11378
Failure to enclose the above requirements will result in a delay in the processing of your part request. Please allow 4 weeks for the processing of your request; allow 6 weeks during the November to February holiday season.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Mar 01, 2009 | Coby DVD-224 DVD Player
I cant program my universal remote to my coby dvd player model 514
need more info. make and model of universal remote? can you program the remote to other equipment? are there codes in the manual for coby dvd player?
Jul 30, 2008 | Coby Televison & Video
Code
I need a new remote control. My remote control just stopped working.
Dec 16, 2007 | kawasaki PVS-10921 Portable DVD Player
Codes for a coby dvd player
I sucessfully programed the AUX button on my Cable remote to my Coby DVD player (model DVD-227) using code 21107. You can also try these codes: 20778, 21086, 21351.
I hope that helps!
Nov 01, 2007 | Radio Shack 15-2104 Remote Control
Looking for Remote Contorl
well according from expierience. i used a different remote from the same model and it works. i believe the codes on the remote is the same thats why
Sep 30, 2007 | Coby DVD-224 DVD Player
Coby dvd 514 remote
BAD NEWS.....I READ THIS FROM THE COBY PRODUCTS WEBSITE: COBYUSA.COM..... What is the code to program my Universal remote with my Coby DVD player? There is no code to program our DVD players with your Universal remote, you need to use the remote that came with the player.
Aug 27, 2007 | Coby DVD-514 DVD Player
Coby DVD-224 DVD Player Logo
499 people viewed this question
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
