Question about Honeywell HHT-145 Air Purifier
HHT-145 tower 3-in-1 Honeywell Air Purifier Won't Re-Start
I moved my purifier to clean the filter and vacuum around it. After cleaning filter, it won't come back on. I tried holding power button as a reset, checking all micro switches to make sure grill was engaging, check UV bulb in securely, made sure HEPA filters in securely, and it still won't power up after 24 hours. Having major surgery on Wednesday and need filtration for asthma. I can't get a response from my vendor or Kaz customer service.
thanks, Gordon 630-879-0217 gordon-campbell@sbcglobal.net
  • Anonymous Apr 05, 2009
    I power it off for a while to wait for new filters. Then I found out it just need to wash or vacuum. But now I cannot power it on
2 Suggested Answers
  • 48 Answers
SOURCE: I moved my hht-145 honeywell
Check the UV lights under the filters. If they loosen slightly the unit quits working. Simple fix, did this myself one time.
Posted on Oct 27, 2010
Gentlemen: The LCD display on top of the purifier indicated that the filters were dirty. We removed the 2 filters, vacuumed both sides and reinserted them. We are still getting an indication that the...
According to what I found, if the filter is not reinstalled just right, it won't trigger the filter being back inplace switch.Also, try unplugging the unit for 30 minutes and then plug it back in. That may reset the switch. If tall else fails, call Honeywell Customer Service at 877- 841-2840.
Hope this helps to solve the problem, JR.
Mar 07, 2011 | Honeywell HHT-145 Air Purifier
Honeywell HHT-011 Air Purifier red light will not turn off even after cleaning the filter three times.
For those who's red light will not turn off after cleaning. There is a little button by the red light indicator. Take a paper clip and hold in for about 5 seconds. Light will then turn off.
Jan 22, 2011 | Honeywell HHT-011 Air Purifier
Can you tell me the difference between the Honeywell Tower Air Purifier HHT-081 and HHT-090? From what I find, they seem identical.
I am 99.9% sure that you are simply looking at this year vs. last year models. There are absoutly no significant changes. I will verify on Mondayas I know the engineer at Honeywell that works on this particular product!
Jan 29, 2009 | Honeywell HHT-090 Air Purifier
After cleaning and replacing filters, won't turn on
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Sep 06, 2008 | Honeywell HHT-145 Air Purifier
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Honeywell HHT-145 Air Purifier Logo
159 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
