Dishwasher is not heating water. Checked heater and ohms were at zero, but electrical leads did not show 120v.
SOURCE: bosh exxcel dishwasher heater problem
Check with multi-meter for power on the heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
You have to test the heating element with an ohm-meter. It should read very low ohms. If the element seems ok, you have to test the controller to see if it is powering the element (probably should be 120 volts)
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
SOURCE: electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P
SOURCE: No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
