I would like my kingston data traveler to boot in unix ,but win xp pro does not see it?
    Sergeant:
    Champion:
  • 334 Answers
You need the drivers for it here is the drivers on this page click in the DTL.EXE and your drivers will be downloaded then follow instructions
God Bless Greg
http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DTI_HS
copy and paste this into your address bar in your browser
Greg
Posted on Dec 15, 2008
Kingston data treveler not format
Hi qais_baba
1...Plug your Kingston data traveler in to your computer
2...Go to desktop and open "My Computer"
3. You will see your Kingston Data Traveler listed there
4...Right click on the Data Traveler
5...Click on "Format"
This will format your Kingston Data Traveler
Please rate me
Bud
Sep 25, 2012 | Kingston DataTraveler 101 G2...
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston data traveler 2.0 is not working.. when i plug it to the computer it tells that the computer doesnt recognize it. i tried to update the driver but nothing is working.. My computer is Windows XP...
May wish to try the following:
1. Use another USB port on same computer
2. Shut down computer, turn-on computer, wait for computer to finish booting up, then plug back-in
3. Use another computer
If the above fail, then it may be the data traveler itself.
When these USB storage devices are unplugged from computers, and NOT safely removed, the USB device becomes unusable.
Apr 01, 2011 | Computers & Internet
I have a Kingston Data Traveler 2GB, but I can't acces to my files. I need the proper driver, where can I get it for free
If you are using XP, Vista, Win 7, ya DO NOT need a driver, as such, the system will install a "Generic" driver, & "It" should show up as a "Drive". If it doesn't, try totally removing ALL USB from Device Manager, and reboot. If it still don't work, then I am afraid it may be kaput.
Jan 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
How to create partition of kingston pen drive
format your pen drive with windows xp setup cd.
Nov 28, 2008 | Electronics - Others
I want driver for kingston 2Gb usb2.0 compatible with window 98
They have just recently updated some of their drivers that include Win 98 and 98SE drivers from the flash drive pens (onces like data travelers) just go to their web page and check.
Good luck
Jul 07, 2008 | Kingston Technologies 512MB DataTraveler I...
Computers & Internet Logo
70 people viewed this question
Alun Cox
David Payne
David Payne
