Dell Inspiron N5030 Notebook Logo
Felicia Evans Posted on Jul 31, 2012
Error code 00f0 1132
Can't logon to Windows 7 When I turn on my laptop there's a blue screeen showing
sarbji tsingh
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 16, 2013
sarbji tsingh
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
58
Points
1 Related Answer
puertobori
  • 7733 Answers
  • Posted on Apr 19, 2012
SOURCE: Srartup Repair Not working?
Try:Turn the machine off, turn it back on and IMMEDIATELY press two keys: CTRL +F6. If you hear a distress series of beeps (around 5/sec) keep pressing for about 1 min. After that release F6 but keep pressing Ctrl for a while.At this point the MS Windows Boot Console should appear and offer you choices. Choose Boot in Safe Mode With Internet.
Now, that combination Ctrl+F6 is maker specific. It worked for my DELL
towers. Other manufacturers reportedly have other "secret" codes.
You may try Alt, Del, PgUp, PgDn instead of Ctrl. Also F6 is not cast in
concrete. You may try other function keys. Some machine may require only one key to be pressed.Every machine MUST have a code like this. It took me about 10 min to find.1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.2. Do one of the following:• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)4. Select a keyboard layout, and then click next.5. Select a user name and enter the password, and then click OK.6. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
Can't reset windows 7 logon password as error
try this :
  1. Download the Reset Windows Password utility onto an alternative computer. Unzip the download file, you'll get the ResetWindowsPwd.iso file. Burn the ISO file to CD using an CD burning software such as ISO2Disc orBurnCDCC.
  2. Set your Windows 7 laptop to boot from the Live CD. To boot from the CD-ROM drive, you may need to press a key such as F8 or F12 while your computer is starting up and set CD/DVD as the first boot device in BIOS.
  3. After the CD boots, you will have a mini operating system loaded into memory which will launch Reset Windows Password utility. It will not install anything to your hard drive.
  4. Click on the Reset Windows Local Admin/User Password option, the program will automatically detect the Windows SAM registry hive and local user accounts existing in your local computer.
  5. Choose the administrator account and click on Reset Password button, it will remove your forgotten Windows 7 administrator password in a short time.
My windows 7 screen shows userinit logon has stopped and some white screen flashes for 1 second and disappears please give trouble shoot details.Thanking you
Buy the real version. We can't even begin to help because we don't know what has been omitted from the OS or added to it. Or even in what way it has been modded to allow it to run without Windows activation.
'' a problem has been detected and windows has shutdown to prevent damage''
From the description it is the hard drive that is the problem, format the whole hardware and re-install your xp windows to see if that will clear up the problem, if not! have the hard drive tested to see if it must be replaced.
Need system unlock code for Dimension E520
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
I'm going to assume by your request above that it is the Windows Welcome Screen User Logon Password.
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
What is the security code for toshiba laptops?
Security Code? I didn't know there was one.
Are you talking about a Password? If so, which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Hello, i have sony vaio VPCEB46FG laptop & i have
You're getting what's known as the 'blue screen of death' as some may call it.
This happens for various reasons, but usually occurs when Windows encounters a conflict with a hardware component in your laptop. When you try to install XP, are you doing so as a secondary operating system (dual OS boot) or are you trying to install it over Windows 7?
If you are installing XP over Windows 7, try doing a full format during setup instead of the usual quick setup. This may take some time, possibly requiring you to format the hard drive overnight but it may well solve any 'blue screen' issues you're experiencing.
Let me know if I can assist any further.
Best wishes,
Graemevm
2answers
My laptop screen is blue with horizantal lines. After I installed a graphics card driver everything went fine, but the next day the laptop's display started acting weird. So I turned off the laptop and...
The OS-loading screen is a stong indicator that thee is nothing wrog with your hardware, but it is a driver issue. You need to press F8 as your computer starts up and enter SAFE-MODE.
Windows 7
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
    Figure 11. Windows 7 Advanced Boot Options screen
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
In safe-mode remove & delete the drivers you installed. If you can, revert to your old driver set.
24helpful
8answers
Forgot password to hp laptop how do i reset it.
I don't know what OS your HP laptop is installed with.
If it is Windows 8, Windows Password Hint, PIN code, Microsoft account can be used to login HP laptop. After logon successfully, change, recover or reset Windows 8 password is available.
If it is Windows 7, Password hint or another administrator account may help you. But if you don't have all of these, try password reset disk. Create it before Windows 8 locked or with Windows 8 Password Recovery tool is OK.
Besides these, Chntpw USB disk also works for Windows 7/Vista etc.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
