Only runs for 15 seconds.
This unit sat around for years before it was given to me. I changed out the fuel, cleaned the fuel filter, cleaned the air filters, and put some fuel additive into the tank in case there was some water I missed. It starts great but only runs for 15 seconds or so. I've cleaned the injector and changed the sparkplug type ignitor. If i disconnect the photo sensor it acts the same way. Does this mean the sensor is bad or could it be the breaker?
Check for a fuel vent line that is stopped up by a dirt dobber at the fuel adjustment screw on the back. We had the same problem.
rsmith@tpsales.com
Posted on Dec 18, 2008
  • 232 Answers
Testing a photocell is a simple procedure
How to test a photocell
Posted on Dec 15, 2008
Starts and idle good wont accelerate.car sat for a year just put another motor in with 115000
Ok ...is the air filter been changed ...start there first.at idle the engine isn't in need of any big air and will use the surface air around it to run.if there is any air restrictions for air to flow it won't .then that's when engine dies.make sure it's getting enough air
Number one thing of all thing that run on gas at fault is the neglected air filter.a engine that runs on gas needs 3 thing to make it go fuel.spark.and you guest it air!
Nov 26, 2015 | Cars & Trucks
87 jaguar xj6 turns over no fire
try quick start straight into air intake or air filter housing while turning over <if it fires up for a few seconds its a fueling problem ,if not more than likely a spark related problem
Jan 16, 2014 | Cars & Trucks
I bought a 00 ford f150 with a 5.4 v8 it has sat for a number of years the story is that the truck started haveing runabilitys ishues so he parked it 2 or 3 years cleaned tank new fuel pump new fuel...
HAVE YOU CHANGED OR CLEANED THE FUEL INJECTORS? ALSO TRY SOME STUFF CALLED "SEA FOAM" I'VE BOUGHT IT AT ADVANCED AUTO PARTS BUT I'D BET IT'S AROUND OTHER PLACES. I PUT THAT IN A 73 CHEVY TRUCK WITH A CARBURETOR THAT SAT FOR MANY YEARS AND IT CLEANED IT UP AND RAN GREAT!!! I WAS VERY SURPRISED!
Apr 08, 2017 | Ford F150 Cars & Trucks
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Lack of power in gas pedal
Check fuel pressure and see if its around 30-35 psi while under load if not replace fuel pump, also the gas thats in the tank may be no good if it has sat for so long..
Jan 05, 2010 | 1989 Oldsmobile Cutlass Ciera
McCulloch 3200 won't run
sorry but really does sound as its only ran for 15 secs on the choke cleaner , we usually change the fuel filter ( thats inside the tank , use a hooked piece of stiff wire to pull it up ) , you will likely need to do a full strip and clean of the carb and fit a new diaphragm the small needle valve may well be stuck into its seat , also watch for the fuel line being perished , and very important , make sure its full of of chain lube oil and pumping correctly ( do this before you even fit the chain and bar )and the chain is tensioned correctly and the clutch and chainbrake operates properly
Nov 18, 2009 | Dryers
TB70ss will not accelerate
Change the spark plug..
Change the fuel filter..
Check the fuel line for crack/splits..
Make sure the primer ball is sealed and not succking in air while running..
If it still acts up - it might need the carb might need to be rebuilt..
If it sat for a long time - the fuel will shellac in the carb and provent it from working properly..
Good luck..
Sep 10, 2009 | Troy Bilt Tb70ss Gas Trimmer
Heating & Cooling Logo
172 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
