Question about Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
How i install wi-fi
Sir i have uninstall my wi fi. now its remove from my system.
how can i install this again.
can its possible from recovery disk
my model number is lenevo 3000Y500
    Sergeant:
  • 320 Answers
Thanks for choosing fixya.com
You can obtain drivers from the manufacturers website.
http://lenovo.com/planetwide/select/selector.html
After you select your country, you then want to click under support where it says "Download software and drivers"
Its then a matter of picking your model, device, and the driver.
Hope this helps you out and feel free to ask further if needed.
Jei
Posted on Dec 15, 2008
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
Drivers acer pew71
on device manager you must uninstall wi-fi driver and then install again.if this not solve your problem change the wi-fi card ; on the back of laptop!!!
May 20, 2013 | Acer aspire 5733z4851 intel pentium...
Wi fi card remove computer startworking
Remove and reinstall driver...possibly replace Wi-Fi card. Are there 2 Wi-Fi cards? Go to device manager (Windows?) and see if it thinks your card is working or not. Yellow ! means it has a problem. And that's where you uninstall it. Reboot and see if that helps.
Aug 23, 2012 | MSI 185 Allinone Barebone Bb A912001BUS...
Wi-fi was blue screen crashing, acer tech support had me do stuff now i have no wi-fi at all
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira.
You should be in pretty good shape if you run and install all of these programs.
Jul 01, 2012 | Acer Aspire 5733z-4851
My wi.fi not working
Did you turn the wireless switch on which is on the side or at the front of the laptop?
May 07, 2012 | Dell Inspiron Mini 10 Notebook
Lost wi-fi facility
Hi, Well you have formatted the system, so you need to install the Wi-Fi driver in order to access the Wi-Fi. ou must be having the driver CD, If you dot have just download the wi-fi driver from internet and install it on your Laptop and re-start the laptop and you will be able to access the Wi-Fi again.
Regards, polysandy
Apr 26, 2010 | Acer Travelmate 2200 Notebook
Some of my programs when I choose them comes up cannot find path missing check required libraries to see if available. Where is this library at
Probably the registry files in the library for these packages has gone corrupt. Locate the installation disks/package for all programs affected. Uninstall each program via it's normal uninstall option or the 'add remove programs' option in control pannel. Then re-install again. This should fix the programs.
Nov 29, 2009 | Computers & Internet
Insirion E1505: Missing Wi-Fi device
I would not open up one of these animals if I could avoid it! Go to the bios, "Disable" the Wi-Fi. Re-boot and ensure NO Wi-fi AT ALL in "Device Manger". If you have the software for the Wi-fi (May be on the System disk that came with the machine) go to "Remove Programs" and take out any software for this device. Shut down completely. Leave for a couple of mins. Re-start and go into bios. Re-enable Wi-Fi and re-boot. re-install software IF requested. Good Luck! Ian.
Sep 28, 2009 | Computers & Internet
I want to install a wi-fi driver in xp operating system
Start - control panel - system - hardware -device manager.
Right click on your " wi-fi", once it is installed and turned on.
Right click again on "update driver"
follow prompts
Dec 06, 2008 | Compaq Presario 5000 PC Desktop
Wi fi is not working
Try to uninstall and reinstall the drivers
Feb 29, 2008 | Computers & Internet
Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook Logo
130 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
