When it starts it's fine, but smokie, leave it an hour or so and it wont start, the plug is very wet and oiley,
SOURCE: Sym Jet euro 50 wont start
if you put to much fuel in the pot you might have flooded it....did you take off the fuel line to make sure you have fuel comming out?if it is not fuel injected.than try changing the jetting in it.does the plug have wet oil on it when you take it out or what color is it?
SOURCE: put new engine in carnt get a spark at plug sym
There may be several things causing this fault (your sure the plug is fine?)
The ignition systems on these bikes are pretty basic. The Stator plate provides power to the CDI unit, which builds up until the pulser tells it to send the power to the coil and produce the spark
1. is there voltage from the stator plate (under flywheel) - you can test with a basic multimeter.
2. is the pulser sending a pulse - also can be tested with basic multimeter
3. is the CDI blown? - swap out to test
4. Is the Coil blown? - can be tested with multimeter
it is also very possible that you may have got a couple of wires mixed up when you switched engines.
SOURCE: sym shark 50 cc won't start. Battery ok, but
have you checked the vacuum tap to see if its working simply remove the smaller diameter hose from the carb and the fuel line its self **** small one to create vacuum and fuel shold come from fuel line if not the tap could be just blocked or the diaprham could be damaged in the tap
Testimonial: "Thanks I'll check it tonight"
SOURCE: repairing a sym euro jet x 50cc scooter all aspects
Hello
Is it a GY6 Motor?
Go to www.scootdawg.com this forum should have wat you need also www.scooterrebels.com as well
Best Reguards
Larry
SOURCE: Hi i have a Sym jet euro x ,It will start of the
The clicking is the starter solinoid.Wire around it and see if starter works.If not replace starter.If it turns over solinoid is bad.
