Question about IBM ThinkPad R31 2656 Notebook
Turn off the Fn
How can i turn off the Fn from my notebook
  • Steve Allison
    Steve Allison May 11, 2010
    Sorry, but your question doesn't mean much; try again.
    Fn is shorthand for F1, F2, etc.
  • 57 Answers
Fn is shorthand for nothing however from what I have searched there doesnt appear to be a method to turn it off at present.
I would like you to try going into the control panel and choosing a normal Keyboard Layout if possible and seeing if that helps.
if not you may just have to hang in there a bit longer.
P.S.: What freetek is referring to is the Funtion Keys not the Fn key. The Fn key is only on notebooks mainly and found on certain keyboards. Like my USB Keyboard.
Posted on Dec 16, 2008
(Fn) key function
Fn or Function key is used for your F1 up to F12 keys. Ex. Fn+F5 is to turn on the wireless capability. Fn key is like a shortcut for the functionality of the machine. You can also adjust brightness by pressing Fn+Up or Down arrow and for the Volume Fn+Left and Right arrow.
Apr 29, 2011 | Lenovo IdeaPad Z360 Notebook
Hi, I am having problem with the screen brightness which i would like to reduce it, please advise.
Hold the Fn key and press f9, You may need to Hold Fn and press f11 to turn off the ambient sensor first. Then you should be able to adjust brightness with Fn and press f9 to lower brightness Fn and press f10 to increase brightness
Mar 09, 2011 | HP Compaq 6910p Notebook PC PC Notebook
I have a advent m201 laptop . how do i turn the built in webcam on please
Try this
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Thanks
Dec 30, 2010 | HP Pavilion dv6000z Notebook
Toshiba Satellite 1905-S301 PC Notebook will not
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
Jun 08, 2010 | Toshiba Satellite 1905-S301 Notebook
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
Step 2 :External Monitor
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook.
May 20, 2010 | HP Pavilion dv6000z Notebook
How to turn off blue keys for an Compaq mini cq10??
if you are refering to the blue letters or alphabets which are present on the keyboard. HP designs keyboard with a billingual layout in some Notebook models.
The HP "Blue" keys are indeed the "French" input keys or other language keys.
How to use the Blue Symbols or keys on a HP Notebook:
We can activate them by pressing Ctrl+fn+right Shift.To deactivate, press Ctrl+fn+right Shift twice, i.e. Ctrl+fn+right Shift then let go off Shift while still holding Ctrl and fn, then press Shift again.
When you press Ctrl+Fn+Right Shift it will switch to the the billigual layout. That means the blue characters become prioritie.
For example, if you are in the billingual layout, when you press shift+6 you will get a '?' but not the '^' sign.
Mar 19, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How do I turn off the blue Fn key?
hi, the FN key can't be turn ON or OFF, this key enable to activate the others key that have a white letter and a tiny blue letter in the same key.
to enable or disable any FN you must press FN + the key that you need to enable or disable.
fosg2000
Feb 22, 2010 | Acer Aspire One PC Notebook
Brand new Toshiba Satellite L305D-S5868 laptop display screen has gone black, even though the computer is on.
Since your laptop is brand new , you may not be familure with it's function keys , FN
Sometimes the users accidentaly presses the FN and the F5 monitor function key at the same time.
which effectively turns the notebooks display off.
D in the image below is the FN function key
and the monitor function key could be F5 , it will have a little monitor symbol on it.
When they are pressed together it will turn the notebooks display off and enable any VGA monitor connected to it's VGA ports. when pressed again , they will turn of the VGA port and turn on the notebooks display.
Thank you for using FixYa!
Az.
Sep 18, 2008 | Computers & Internet
IBM ThinkPad R31 2656 Notebook Logo
295 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
