Back to:
Tags:
Atlantic 63535215 Nova Home Theater Main Unit System
My home theater receiver says that my movies are... (by 3 users)
By Beresford - usenet poster
My home theater receiver says that my movies are being played in Dolby Digital 3/2.1. Is that the same as Dolby 5.1?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by northern guy, posted on Apr 10, 2008
My cable box and HD DVD are supposidly sending out the audio signal in Dolby 5.1, but my 5 channel amp shows on its digital display it is recieving the signal in Dolby 3/2.1 I am using an optical patch cord. I have tried a HDMI cable with the same results.
Comment by volla7, posted on Jan 13, 2008
My dvd player plays a dvd half way and then it starts yerking,what can i do, it looks like over heating. I have put a fan on it and it help a little bit and then start yerking again
Where can i get a workshop manual
Best Solution
posted on Aug 08, 2005
Helpful (85)
Ross
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes, it is the same. Some recievers just have it labeled diff'rently than others. Yours shows that you have 3 front channels/2 surround channels and one low frequency channel.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My home theater receiver says that my movies are being played in Dolby Digital 3/2.1. Is that the ....:
I don't want to Accept this solution
Solution #2
posted on Feb 29, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Hello Volla7.
Here is a link to Panasonic parts: http://www.pasc.panasonic.com/Epartr/PartsList.asp
Here's a link to the actual Panasonic SC-HT743 product page.
Not sure what you mean by "yerking" - I am guessing skipping. DVD players will get warm in normal operation. If using a fan, make sure the airflow is correct and not redirecting warm air back into the unit. If the DVD is skipping, try anohter disc to see if the results are the same (rented DVDs are notorious for scratches). If you have a suspect DVD, purchase a cleaning/restoration kit.
Hope all of that helps give some direction.
JE - www.hometheaterbids.com
Thank You!
Solution #3
posted on Oct 01, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
no first u have to check whether the dvd is in 5.1 encoding or not before loading in dvd player.then go to the setup of ur dvd player then select 5.1channel.after that go to the menu of ur receiver and select dolby digital in 5.1 channel mode .i hope this will help u out
thanking u
yours
prateek
Thank You!
Can you Help with these Home Theater Systems problems?
DVD Player currently locked in to region 4 (Australia). Is...
My panasonic SA-HT700 dvd player/home theater system will...
The 2amp fuse (Si5) blew and on checking, the T105R (BD135...
I just bought the optoma H 31 used. I am a photgorapher...
My HT-TQ72 home theater system shuts down itself in a...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
