Cannon mp130 printer waste tank full so will not print
  • 552 Answers
This appears to be a "full ink tank" reset problem.
Here is a solution------Ink tank reset codes------
CLICK HERE
Posted on Dec 15, 2008
Waste ink absorber full
You need to change the pads or you can reset the waste tank counter. Here is the reset sequence if you choose to do it.
The reset procedure is:-
Turn on the machine
(1) Press MENU
(2) Press SCAN COPY SCAN to enter service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
DONE !
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Message-the waste ink absorber is almost full on pixma MP130
That is usually Canon's sneaky way of telling you that is nearing time to buy new printer. Used on older machines without chips on cartriges. After "almost full" msg, usually follows "waste ink tank full" after which printer becomes unusable. Solution: Google "waste ink tank full" reset tool and run it, that should do the thing.
Oct 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
MP130 Ink waste tank is full how do I empty it
To reset the Waste Ink Counter:---------------------
  • Press Menu----------- Scan -------------- Copy----------- Scan, to enter Service menu.
  • Scroll to option " Service Menu Counter Access ".
  • Press OK.
  • After entering Scroll to " ABS-M DOT COUNT ".
  • Use arrows to reset the value to ZERO.
  • Press Stop or Reset.
Thats the Solution.
To Clean Waste Ink Pads:-----------------------------
  • Open the cover ( the cover you open to replace the catridges ).
  • Locate the Waste Ink Pads which are situated in the or under the Catridge Slider.
  • Dry up Waste Ink Pads ( You should wear Gloves when holding them).
  • Rinse the pads with Alcohol and make them dry.
  • Replace Pads .Then Set them. Make sure they are sitted properly.
Thank you Sir, I hope I helped you. Have a nice day.
Sep 21, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Canon PIXMA iP90 InkJet Printer
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Canon i470D Waste Ink Tank is Completely Full. How Do I Clean It?
There is a cleaning solution sold on E-bay for Cannon i470D print heads.
Or you can try a little ammonia. I used a cap full of ammonia in each side of the print head where the ink tanks go.
Put the print head in a can and let it set in the ammonia for 5-15 minutes then blot dry with paper towels and let stand until dry.
Then run the maint routines for the print head found under properties/maintance.
Dec 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error (5800)
Waste ink is full counter reset.
Sep 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink
yeah try this.
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu, Copy, Scan, Copy, Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Jun 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon MP130
0.gif Re: CANON WASTE TANK RESET CODES for Canon MP130 by tac (2/15/07 1:52 PM) reply + / - CANON MP130
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will include printer.
2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and advance value equal to zero.
5. select SET Abs- r level (if there is) and also you will establish into zero.
6. you will turn off printer by button POWER.
215 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
