Question about Gaggia Titanium Espresso Machine
The Display shows VENTILATE
Hi can anyone help me my Titaniun pump started to get very noisey and now wont pump water then my display shows VENTILATE
  • 3 more comments
  • barryrobbins Dec 16, 2008
    Hi thanks for the info since posting the notice I have since found that the flowmeter assy seems to be blocked not allowing water to oass through it if I bypass it the machine will pump water but still cant get it to ventilate I will attempt to remove the flow meter and see why it wont let water through it
  • jimmyknows Dec 16, 2008
    I have the same problem and I can't make it go away.
  • barryrobbins Dec 18, 2008
    Hi I have fixed my Titanium The problem was a coffee bean dropped into the water valve and when the water container was refitted it broke the bean up which in turn blocked the flowmeter which sttopped the machine from pumping water I found the blockage and its all working fine now
  • Anonymous Dec 21, 2008
    I had the same problem with Ventilate never going off. Thanks to Barry I found a coffee bean in the water valve between the water reservoir and the inlet. I removed it and the problem was fixed!
  • Julie Higham
    Julie Higham Jan 05, 2009
    My titanium has been the best and worst purchase we have every made ! When it is working it is like a dream but we are plagued with differing problems now its the ventilate problem .I have tried the resetting to factory -not resolved I have pressed the tear drop button and opened the valve the closed it-Not resolved .I have read other threads if i open it up inside where is the flow meter assay> and how can I tell if this is blocked .Fortunatly it worked like a dream over christmas but it just appears to have given up! Gaggia Uk are not really that helpfull and it will cost £60 carrage before i start.The last time it whent strange this website was wonderfull in resolving the issue and it has worked well since. Thanks in anticipation
Press the button that looks like a drop of water.
Open the steam dial and place a cup underneath (or just direct it over the drip tray). As soon as you get some water out turn the dial back to off.
That's all you need to do, it should now say ready to use.
The pump is noisy because it doesn't have water in it. Pumps don't like that. The ventilate sequence primes the pump with water.
I just had to do this after a de-calcify cycle.
TK
Posted on Dec 15, 2008
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
The coffee machines say ventilate
Hi
You need to run water through the wand to prime the machine. Push the button that has or says water or a drop. The display will say "hot water". When the "ventilate" disappears it will say "warming up". You are primed.
Oct 15, 2009 | Saeco Royal Professional Espresso Machine
Ventilate message, but no air in system
HI Sorry, but that sounds like a bad flow meter. The flow meter is not that hard to replace, with a little common sense, but the new flow meter should be the brass one. There are some tricks to getting the top back on, Pull forward on the bypass doser chute a little so it will center in the opening. You don't have to disconnect all the wires that go to the top. They are long enough that the top will set behind the machine carefully. Remember the tubes that go to the flow meter. You don't want to get them backwards.
Jun 14, 2009 | Saeco Royal Coffee Bar Coffee Maker,...
Nead help pleace
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 15, 2009 | Saeco Royal Digital Plus Coffee...
Machine wont start
fill it with water start the machine when hot open side valve to let water out if it doesnt do the job remove water tank in the kit of the machine there a little pump put water in the pump in the water hole force water in there with side valve open let me no pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Ventilate will not disappear from the display,and the machine wont work
the procedure is filling water tank opening side valve that should clear the ventilate if is still there remove water tank apply water pressure with pump in the hole of water tank let me now pierre
Saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
196 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
