Pure Legato DAB wont power up
I have a Pure Legato DAB & CD player, it has power going in which lights the front screen (nice blue backlight) but nothing else happens. And my last CD is stuck in the tray. ha. Any ideas what tests or how to start working through testing it to find the fault. I have hard hat these get hot and do seem to fail but mines been working well for near 3 years (although that means its out of warranty).Thanks Richard
  • 1 more comment
  • sarahjjarvis Dec 21, 2008
    Hi, I've just experienced exactly the same problem with mine and have just emailed their web support email address in case there are any tips. Will post any advice I receive.
  • plumber12 Dec 27, 2008
    I have the same problem on a brand new unit
  • delta3 May 19, 2009
    We have the same problem on a refurb unit that was a replacement for our original unit that had... the same problem! So two units - the same problem. We are outside the warranty period on the refurb unit, so no more replacements.
    In both cases the problems started with poor radio reception followed by the 'won't power up' problem in the original post.
  • 287 Answers
SOURCE: zd8000 wont boot up
try to get into SAFE mode... tap F8 repeatedly when you first power on. You should get a safe mode boot menu, select last known good profile and press enter.
If this does not work reboot go into SAFE mode and select Safe Mode from menu and see if it will boot up.
You may get a pop up to use system restore, say yes, select restore to an earlier date (or similar) then use the calander to select a restore date that is PRIOR to the problem starting.
If this does not work boot to safe mode again and say NO (cancel) to use system restore and see if you can get to the desktop
post back results for further troubleshooting
Posted on Jul 16, 2008
  • 1028 Answers
SOURCE: kenmore eliete washer fails to do anything
probably bad main control under top left rear ..ck for bad connections first just in case
Posted on Aug 21, 2008
  • 2326 Answers
SOURCE: Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
VOTIT
  • 2071 Answers
SOURCE: won't power up
Yes this is a power supply problem,you better replaced the regulator IC there or replaced the whole board,so it will works normal again..
hope this may help you;
DON'T FORGET TO RATE:
Posted on Sep 04, 2008
geminii_lady
  • 87 Answers
SOURCE: Dell Inspiron 6000 Memory - Crash Problem
get yourself a 2.5 hard drive box (no hard drive in it) costs less than a tenner on ebay. Remove hard drive from current laptop, put it in box, connect to another laptop via usb provided and you will be able to read from it like it's a flash drive or cd. Then just copy files you need to other laptop or CD. No damage done to original hard drive. Put your hard drive back into laptop.
This part, am just taking a guess at but then see if you can do a system restore to a date previous to problems ie when you updated in case it was the update that caused the problem. If you had XP disk and ID number you could try a repair or a reinstall but that is pretty drastic. No way should you need a new computer
Let me know how you get on. IF you don't know what I mean by the HD box, just shout and I will be more specific
Good luck
JEnny
Posted on Oct 23, 2008
When i switch on my pure legato cd 40 the screen comes on then goes of the system works fine but i can't see the screen to access the menu can any one please help thank you.
This kind of problem is certainly a hardware problem, and there are two possibilities:
1) Problem with light background or its voltage source: you can try to see closer direct to display for some caracter with an external light source (like portable light). If you can see some caracter, you should measure voltage wich feeds display backlight and follow its voltage line.
2) Display (or driver display) damaged: If you dont see any caracter signal, you should replace the whole display module.
Dont forget to rate
Oct 30, 2013 | Computers & Internet
The CD player in my Pure Legato 2 system won;t register CDs, the last few times I listened to CDs they skipped a bit, now it won't play them at all, it just reads 'no CD'.
I have fixed this problem in 2 Legatos. But don't attempt this if you have no experience with electrical equipment.
You need to open the case (4 screws deeply recessed in the back panel, 3 screws securing the speaker terminals and the phono socket block, and the nut and plastic washer holding the aerial socket. Gently ease the rear panel back enough to access the rear of the CD mechanism. Under the CD laser assembly carriage, there is a small trim pot (with a yellow cross-head adjuster screw). I found a small anticlockwise adjustment got the CD player working again. (I assume this trimmer increases the gain of the optical sensor amp.) Secure the rear panel before powering on again to test. It may require a little trial and error to recover the full functionality of the CD.
Good luck.
Feb 09, 2010 | Audio Players & Recorders
I'm installing a pioneer deh- 2750mp cd player into a '92 Ford Laser, and was wondering how the wire colours match up?
Hello! Ford wiring
Power
Constant +12volts Green/Yellow
Switched +12volts Yellow/Black
Ground Red
Power antenna Blue
Illumination Blue/Red
Speakers
Front Right + White/Green
Front Right - Green/Orange
Front Left + Orange/Green
Front Left - Light Blue
Rear Right + Pink/Blue
Rear Right - Green/Orange
Rear Left + Pink/Green
Rear Left - Pink/Blue
Guru..............saailer
Jan 22, 2010 | Pioneer DEH-2700 CD Player
I recently moved my Legato Pure radio, now I have trouble tuning in the DAB radio and the display struggles to set the clock often flashing with a message saying it is wating for time to set. When it does...
Clearly, the DAB signal strength is poorer in the new radio position. Try moving it, even a foot or two can make a difference. Better still, use a roof aerial.
The display can be changed, even in standby mode - press the Display button to see the 3 options.
Dec 19, 2009 | Audio Players & Recorders
2002 malibu wiring diagram?!?!?!?!?!?!
ok, the red and yellow wires serve 2 different purposes.the yellow supplies constant power to your stereo, and the red is switched power. what youve done is combine the two, and connect them to a constant power source. like this, your stereo wont be switched with your ignition. so take off the red wire, but leave the yellow wire connected to the wire its already on. make sure your stereo fuse is good in the fusebox of the car. then, use a test light, with the ignition switch on, to find the second wire on your cars harness that has power. that will be your switched power. connect that one to your red wire, and that will solve your problem.
Aug 04, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Connecting my cd stereo to 1990 Ford Taurus
since it worked before and you didnt change anything and now there is no power it looks like you blew a fuse when connecting wires. check the radio fuse on the door panel, and check the int. lighting fuse under the hood of the car. take both out and see if they are blown, if blown buy new fuses and replace.
heres the wiring diagram for a 1990 Ford Taurus:
Left Front (+) orange/lt green
Left Front (-) lt blue/white or Blk
Left Rear (+) pink/lt green
Left Rear (-) dk blue/ orange or Blk/Wht
Right Front (+) Wht/Lt green
Right Front (-) Dk green/ orange
Right Rear (+) pink/Lt blue
Right Rear (-) Tan/White
Lt green/yellow Hot at all times
Black - Ground
Yellow/Blk - Ignition
Lt blue/red - Acc
Orange/blk - Dimmer Lights
RED - Lights
Aug 22, 2008 | Car Audio & Video
CD PLAYER NOT WORKING
laser lens broket..replace entire cd player by exchanging a $20 bill at a local merchant.
Feb 12, 2008 | Audio Players & Recorders
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
722 people viewed this question
 Grubhead
Grubhead
