Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Lens jammed when switching on/off
The Lens jammed when I switched off the camera, it now just makes a whining sounds when I switch on/off the camera. Any ideas on how to unjam this would be appreciated.
  • Guy Hoogewerf Apr 02, 2007
    Still struggling here if anyone has any ideas please let me know...
  • Guy Hoogewerf Apr 04, 2007
    I did the Canor repair people wanted £62 just to look at the problem, then were going to charge an extra £40 for the new lens if that was the problem, either way I was in for a £100 bill on a camera that costs £119.00 new... thus my desire to repair it, or buy a new one...
  • 75 Answers
The lenses on this model is impossible to dismantle and repair. It is best to take into a Canon repair shop.
Posted on Apr 04, 2007
Camera will not operate
I had that issue once and it was the lens, not the camera. The autofocus gears were stripped.
Have you tried other lenses yet?
Jun 28, 2014 | Konica Minolta Maxxum 7D / Dynax 7D...
MY CAMERA KEEPS TELLING ME TO SWITCH OFF WHEN I SWITCH ON AND THE LENSE WONT RETRACT FULLY WHEN IT SWITCHES OFF
Usually a result of a lens jam or some dirt/debris/sand getting into the lens mechanism.
Not much you can really do about it except to have the lens replaced. There are
some ideas to temporarily fix the problem, but it will probably happen again.
If you suspect dirt/debris or jams were not the cause then maybe the lens just needs
to be reseated.. just gently tap the side of the lens with a pencil and keep your fingers crossed
Jan 23, 2011 | Sony DSCW320 Digital Camera
When i turn on my canon ixus i7 its say on the screen lens error, restart camera
this usually happens when lens are stuck, the reason for this is duct, could be the camera has dropped down, or the gears are jammed, now to make it work, while switching your camera on, try to tap very gently, near the lens, should make it shake in prior to make lens come out from jammed position, try this several times...it should work, if it does not, then take it to qualified service tech
Oct 28, 2009 | Canon IXUS i7 Digital Camera
Jammed lens
would be best to send to repair center
Sep 17, 2008 | Olympus FE-210 Digital Camera
The mirror is halfway up, and will not move when you actuate the shutter, for my Pentax MZ-30. Any button I push or switch I move, makes the camera make a whinning sound and nothing happens.
Try to remove the battery with the camera in "OFF" then reinstall the battery (make sure the camera is off) and set your top right dial to the "P" (Pict position). Make sure the switch to the lower right front of the lens mount is set in AF. The n power the camera body back on. This should resolve the problem.
If not there may be a foreign material jamming the mirror.
Aug 03, 2008 | Cameras
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Camera makes clicking sound but doesn't take pictures
The gears in the lens are either jammed with sand etc. . or broken. Most likely you need a new lens assembly, although sometimes the gears can be replaced.
Dec 04, 2007 | Fuji FinePix A303 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
