Question about Price Pfister Ashfield Single Control Lavatory Faucet ...
No cold water from bathtub fixture/Shower won't engage
My bath tub fixture will not let cold water out. Nor will it activate the shower.
Can you help me on this?
It does not have two seperate hot/cold taps, just one where both cold/hot are mixed.
  • 1 more comment
  • bakerboy4920 Mar 21, 2009
    Found out that the mechanism inside the faucet was bad. Price Pfister sent me a new one. All I had to do was pay shipping.
    Also determined it was a two fold problem. The divertor valve in the tub spout was bad too. Price Pfister sent me one of those too.
  • Anonymous Mar 31, 2014
    Faucet wouldn't run hot and cold water together. Now no cold water at all comes out of faucet.
  • 101 Answers
If you put on the cold and Nothing at all comes out, check the water supply valve to the tub. If it comes out alittle ...the washer probiblly came off and is stuck you will have to remove the valve ,but 1st check that the handle is not stripped ,and that is actually moving the valve to the open position Turn the handle and see if the handle backs out ,like its trying to open.
Please rember to leave me some positive feedback if Ive been Helpful! Thanks !
Posted on Dec 16, 2008
Should I replace my only bathtub with a shower?
that is up to you
but consider this
Age or physical problems makes baths difficult and dangerous
so a shower stall with a seat is a better properisition
next showering last for around 7 minutes and that amount of water is less than 1/2 tub unless you stand under the shower until the hot water runs out
lastly , I have never considered it hygienic to wash you face in the same water that you wash your rear in
Apr 07, 2018 | Home
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
Does Kohler recolor existing fixtures? Do you have pedestal sinks and tubs for art deco period such that one could get a light teal or purple tub or sink?
The companies don't recolor fixtures but there are bath refinshing outfits that do. There are also do it yourself kits to be had. I did a harvest gold shower once and it still looks good after 7 years.
Feb 08, 2011 | Kohler Overture 5ft Vikrell Bath -...
Water is hot when in shower mode but when in mode to fill bath it is only cold
Do you have separate faucets for the tub and the shower?
Jun 28, 2010 | Home
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Single handle moen bath fixture only lets out hot water
remove the cartridge and see if their is anything blocking the cold inlet.If you dont see any dirt than that means that the cartridge needs to be replaced
Jan 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Price Pfister Ashfield Single Control Lavatory Faucet ... Logo
1,443 people viewed this question
Top Price Pfister Plumbing Experts
Marvin
Marvin
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
