Question about Southwestern Bell (S60802)
Need manual for SBC Freedom Phone Model HAC FC2548
I need to know how to program speed dial numbers
  • 449 Answers
To programme speed dial just go to contact on your phone menu and select the conatct you want to speed dial and assign speed dialing number for the person or you type any number on your phone and press the harsh key like this (10#) and it will bring out the number assign to that spedd dial
Posted on Dec 17, 2008
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
No manual available to show me howto set speed dial function on my FC 2556 Freedom phone?
kindly download the file via this link:
http://phone.manualsonline.com/manuals/mfg/southwestern_bell/fm2552_1line.html
Southwestern Bell Telephone All Models 2-9193 26955 DKS930 1-Line FC2548 1-Line FF908 900 MHz 1-Line FM144 FM2552 1-Line FM2552/FM2000 FM2552PX FM2560 FM2572 FM4484WW 1-Line FM891B 1-Line FS800 FS900 1-Line FT-412 FT365 GH 3034BL GH 3210 2.4 GHz GH5810 GHz 1-Line
just set the right model if this is not the right one...
---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial----- ---if I help you please help me---
Thank you for choosing fixya
Roger
Sep 02, 2011 | Southwestern Bell Freedom Phone FM2552
I have a toshiba DKT3512S and need to reset the time, also i would like to know how to do speed dials. Thanks mara
You will have to get into program mode for this. you will have to press this sequence of buttons. Hold*#*#1*2*3*. Password is default to 0000. Program number is 902 then press hold. Press Intercom button for Date and line 1 button for time. If you press Intercom #66 enter speed dial number 10-99 is station speed dial. If you press Intercom #66 and enter speed dial numbers 100-999 will be system speed dial. Hope this helps. I included a site below with program manuals.
http://www.wedophones.com/ToshibaManualsLead.htm
Oct 12, 2009 | Toshiba DKT 3010 Corded Phone
I need to find owner's manual for Southwestern
Dear Sir,
By typing "Southwestern Bell Freedom Phone Manual" in Google, the first description on top of the page I clicked on showed me a variety of catagories of phones to choose from. I clicked on the corded phone catagory and I chose FC2548 which was the closest to my model FC2570. I downloaded a pdf of the owner's manual which solved my problem of saving numbers to memory and
other functions.
Sincerely,
Bruce Hyman
Jun 04, 2009 | Southwestern Bell Freedom Phone FM2552
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
Euro style 18d how to program memory keys
The Avaya website (www.avaya.com) is loaded with manuals, you just have to know where to look.. Here's one http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Page 13 tells you how to program a button (ie FEAT 00 button dial the number and press FEAT 00 again to exit). Page 16 tells you how to program personal speed dial number from the 20 bins 80-99 allotted to your phone.
Carl
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Programming speed dial!!
ARE YOU PROGRAMMING PERSONAL SPEED DIALS, SYSTEM SPEED DIALS OR BUTTONS ON THE PHONE AS SPEED DIALS.
IF SYSTEM YOU MUST BE ALLOWED IN THE PROGRAMMING BY YOUR INSTALLER TO DO THESE UPGRADES. NORMALLY THE RECEPTION/ FIRST EXTENSION ON THE SYSTEM HAS THIS ABILITY. ADMIN PASSWORD IS 1234 PROGRAM 001 IS WHERE YOU PUT IN THE NUMBER AND 002 IS WHERE YOU PUT IN THE NAME
UNDER MANAGER PROGRAMMING, PAGES APPROX 210-215
Apr 28, 2008 | Panasonic KX-T7730 Corded Phone
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Southwestern Bell (S60802) Logo
403 people viewed this question
Top Southwestern Bell Computers & Internet Experts
David Payne
David Payne
Are you a Southwestern Bell Computer and Internet Expert? Answer questions, earn points and help others
