Question about Whirlpool LER4634J Electric Dryer
Whirlpool ler4634jq0 Has had problems for many years eating up the idlers, replaced 2 weeks ago started making bad sounds within first week. noticed rear drum seal has some worn spots could that be the problem? inspected drum didn't notice anything wrong but I am just a newbie at dryer repairs. Baszman
  • Whirlpool Master
  • 8,220 Answers
Your rollers probably need replacement. Get a bonified FSP idler instead of a crappy made in asia knock off. Check your drum slide. Rib side down with the belt to the drum.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 18, 2008
2006 Cadillac cts is burning gas faster than the normal rate after i got an oil change at jiffy lube 2 weeks ago
I dont think there is a connection between an oil change and the gallons per mile.
With that age car, I suggest a Terra engine clean. It will blow away nine years of gunk from the spark plugs, fuel injectors, cylinders and exhaust. Should give you more power, more miles..
Mar 18, 2014 | Cadillac CTS Cars & Trucks
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
My WBXR1060TAWW GE washer is eating thru belts....I replaced one about 2 weeks ago and the new one is fraying badly. It looks like it's rubbing metal when going through the spin cycle... It all started...
tensioner pully could have bad bearing when ran gets hot and tries to lock up causing premature belt wear. spin all pullys with belt ff any hard to turn or so loose they might fall apart
Jun 21, 2009 | Washing Machines
98 Olds 88 starting problem
I know it sounds crazy but check to see if the floor mat is blocking gas pedal. I have seen this alot in my 30 years as a master tech.the way you describe it sounds like all the other cust of mine that had the same issue. hope that is all it is. good luck and let me know.
Jun 02, 2009 | 1998 Oldsmobile 88
2003 Toyota Corolla 30 amp keep blowing
it sounds like when the cat was changed they have trapped a wire or just moved one over a bit and its rubbing think about what items this 30amp fuse is protecting are any of the items close to the exhaust or around that area, i dont see the aftermarket starter doing this after 2 years hope this is helpful regards JR
May 17, 2009 | 2003 Toyota Corolla
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
The gas das't start tere for dryer goes for long time without drying the klotnes
Nov 06, 2008 | Whirlpool LER4634J Electric Dryer
Top rack dishes are not clean
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with EVERYTHING..to no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Aug 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LER4634J Electric Dryer Logo
162 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
