Question about Dell Inspiron 6000 Notebook
Yellow battery light
My battery lite on the hinged part of the machine is constantly blinking - 4 yellow and one green constantly. Does that mean I need a new battery?
  • Anonymous Jan 03, 2009
    i too experience 4 yellow flashes 1 green and screen says con. fig . files corrupt or missing not allowing computer to boot up
    this occurs when using ac adaptor or in batttery mode
    Problem Solver:
  • 6 Answers
Thx_nb said may be right. check this site: http://www.laptopbatteryweb.com/dell-inspiron-6000.htm
  1. Battery Brand :Dell
  2. P/N# :Inspiron 6000 battery
  3. Battery Type :Li-ion
  4. Voltage :11.1V
  5. Capacity :6600mAh
  6. Color :Black
  7. Dimension :209.40 x 71.80 x 19.80mm
  8. Net Weight :578.33 g
Posted on Jan 03, 2009
  • 242 Answers
It indicates there is a problem with your battery. You'll need a new one.
Posted on Dec 15, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Center (yellow) light blinks consantly
actually that one blink says a user fault, says to release joystick and put it innuetral and try again,can only tell you what manual for invacare says,me id have a dealer tech look at it, check voltage of batterys,first please
Dec 06, 2013 | Invacare Health & Beauty
My game only works when on charge. When the charger is pulled out the games turns off. When on the charger base there is a constant blinking green light.
  • That blinking green light means the rechargeable batteries are no longer holding a charge which is also why the unit shuts down when the power feed is removed. You just need a new set or rechargeable batteries is all. 4 AA (or LR6 depending where you are)
  • Please note that when the charger rapidly blinks green, in addition to the batteries that are failing, they can overheat and leak. Please, cease to use those batteries and take them to a recycle place before they begin to leak from trying to charge when they are not safe to charge anymore.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards,Tony
Oct 05, 2011 | LeapFrog LeapSter L-Max Console
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
I have a nespresso latissima machine,Got it for x-mas, and now there is constant yellow light on the water (the tank is full, and there is a blue light when it is time to fill it up...) What does it mean?
I just had this same problem with my brand new Latissima premium and I fixed it by adjusting the water hardness setting. The yellow water warning light being constantly on means the machine thinks the water is too hard and the machine needs descaling. In my case, the machine just needed to learn how hard my water actually is. In the manuals that came with the machine you should have been given a ph testing strip and there are instructions in the user guide about how to adjust the water hardness settings. As soon as I did that, the yellow hard warning light immediately went off. In my case the water setting needed to be adjusted to the 7-14 ph setting. I'm attaching pics of the water hardness setting instructions from the manual.dberlyne_3.jpgdberlyne_2.jpgdberlyne_1.jpgdberlyne_0.jpgdberlyne.jpg
Dec 28, 2009 | Nespresso C190 Espresso Machine
PC will not turn on blinking green light on power supply
The green light on power is blinking, it means power supply working in main power and the main supply not constant that time after constant the green light, then turn on the PC.
Thanks
Aug 13, 2009 | Intel SR1350-E Server Chassis...
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Feb 07, 2009 | Nintendo DS Lite Console
Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Dec 27, 2008 | Canon S400 InkJet Printer
We have the sidekick slide...this is the 4th one. it keeps shutting down completely. there is a flashing light which is like a yellow/green on the directional pad and we don't know what that is and it...
Back with a solution!
All you have to do when you have the yellow lights blinking and you cant power your phone on/off, is put your phone on the charger for about 15-20 mins. I think it has something to do with the battery. Hope this helps =]
Mar 14, 2008 | Lands Phones
Dell Inspiron 6000 Notebook Logo
222 people viewed this question
Alun Cox
