Question about Ricoh Aficio 1013F Copier
Code f32, f26
Please my konical 1212 machine is dislaying the above codes and nothing is working on the machine again please what can I do to overcome this problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
F 26 is for toner denisty sensor .just clean this one.f 32 is heater unit problem temperature of heater unit is very high.just reset it by 25 mode code p 47 set it to 0..'press 2 and 5 key before power on copier u will enter in this mode.by mian jee
Posted on Dec 16, 2008
  • MIAN Dec 16, 2008
    f 26 is for toner denisty sensor .just clean this one.f 32 is heater unit problem temperature of heater unit is very high.just reset it by 25 mode code p 47 set it to 0..'press 2 and 5 key before power on copier u will enter in this mode.by mian jee.
What does f26 mean for siemens washing machine
F26 come up This error code indicates that the door needs to be opened and closed.The F26 code may appear the first time you try to use the washer. Open and ...
Jan 03, 2016 | Siemens Washing Machines
How do I repair F 26 on a Kenmore frontload washer
if you get the F26 error code, Press Stop, Open the door, press the black button just above the right middle of the machine opening, above the latch, hopefully, you will also hear a click, and then your machine will work normally.
Sep 01, 2014 | Kenmore Washing Machines
My maytag commercial washer display a code F26
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
Trying to find the radio code to a Hyundai getz 2 2005---kmhbt31ar5vio3845
have just heard you only need the last four (4) numbers.
but you must add 1212 to the numbers, if your first number is 3 add 1 to make 4, if the second number is 6 add 2 to make 8, third number add 1 again and so on
Nov 27, 2009 | Vehicle Parts & Accessories
My Whirlpool Duet has just come up with F32 error on display. Any ideas please?
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
Nov 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer is throughing a code
Here's a solution from an old posting of the same problem in a different Kenmore washer:
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing thethree screws in the top back of the washer.
2.Inside the back rightcorner is a round plastic box, fastened to the side with a plasticsnap. In will have a wire connector and a small, rubber hose connectedto it.
3. Check to make sure all the connector wires areconnected and tight. Unplug washer for 30 seconds to reset it. If the cycle failsstill with the F32 code, you'll need to replace the Water Level Switch.
4. Ifthe Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Aug 09, 2009 | Kenmore Washing Machines
Konica 1212 again!
Try "47" 51 it is possable to try the set up run again before but wait until the machine finishes its cycle if you still get F26
replace the deveolper.
Thank you
Feb 20, 2008 | Office Equipment & Supplies
134 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
