Question about Akai LCT2715 27 in. LCD Television
Sounds goes off on it's own
The sound goes off on it's own after the TV has been on for a while. I don't have the timer, sleep or mute on. What should I do?
Any suggestions?
  • 30 Answers
These TV's are prone to power supply failure and this sounds like it may be the case for you. I offer to repair/recondition the power supplies in these TV's for a flat rate and I also have an instructable on how to remove the power supply located here ( http://www.instructables.com/id/AKAI_LCT2715_Power_Supply_Removal/ ) If you are interested in having your power supply repaired you can contact me in my profile ( http://www.fixya.com/postBuddyProblem.aspx?budid=763646 )
Posted on Dec 18, 2008
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Since changing to freeview in april i no longer need the use of the original tv remote as the new remote is being used. my problem now is i cant find how to set the tv to sleep mode shud i fall asleep...
Your new FreeView remote will only support the essential functions of your tv. In some cases that's limited to volume up and down, sound mute and on/off only, but often they can do more. Sleep timers are rarely supported.
Your fix is to either set the sleep timer on the old remote, or to buy another fully programmable learning remote control, where you can customise almost every button and use your old remote to teach the learning version its tricks.
Jul 22, 2011 | Televison & Video
My tv keeps going off at every 30 minutes where is the timer,it also blackout
sounds like sleep timer is on. look on remote for sleep button or it may be in tv menu.
Jan 23, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Need help
try to press the timer button repeatedly untill u see time 00 is desplayed may be u solve your problem if it is in sleep timer mode and if u managed to rset timer to 00 and the problem persist your tv has a high voltge problem it delay to charge the tube.
Sep 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
No sound,volume bar works
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
Aug 31, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Akai LCT2715 27 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
