Question about Samsung LN-S4692D 46 in. LCD HDTV
Connecting my DVD player to my widescreen TV
I have a Coby DVD player with a three prong cable ( red, white and yellow) i need to connect it to my Samsung wide screen TV.
  • willieb3110 Dec 15, 2008
    Thanks for the help, it worked. Real simple when you know what buttons to push.
PRETTY SIMPLE, CONNECT YOUR 3 PRONG CABLE FROM VIDEO AND AUDIO OUTPUT ON THE COLBY DVD TO THE INPUT VIDEO/AUDIO ON THE TV.SWITCH AV INPUT ON THE TV TO VIDEO 1.
Posted on Dec 15, 2008
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
Can you provide a user manual for an Inovix iDP-713D Portable DivX DVD Player Widescreen 7" demonstrating where input to a 40" flat screen Samsung UE40C85UKXXU goes?
On the back of the TV you should see the component connections. Connect the Yellow plug to the Green/Y terminal. Connect the white plug to the white audio terminal and red plug to the red audio terminal. Change your TV input to Component and you should be set.
Nov 26, 2014 | Samsung Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Coby DVD-937 playing DVDs in Black and White
you did not connect it to the right port in you tv with the right cables. if it came with a cable using red, blue, and green wire you need to connect all three to the appropriate place on the tv in this case the red is a video cable and not audio they are white and black in component video... if it is the other way around you have a red white and yellow cable the red and white are audio and yellow is the only video and needs to be connected to a yellow jack on the television
Jun 23, 2009 | Televison & Video
How do I hook up my new coby DVD recorder/player?
What you will have to do is just two of the inputs coming from dvd to the tv.
You should have red, white and yellow coming from your dvd. The Yellow is usually used and is marked on your dvd as the video and goes to the video on your tv. You can use either the red or white for the audio input into your tv. You have an older type tv but that is all that is necessary. Video to video and one audio only to the other audio input on the tv. good luck.
Jan 14, 2009 | Coby Televison & Video
Coby DVD player set up
Brenna,
Here are some things to remember when messing with cables TO and FROM electronic audio/visual
devices. YELLOW connectors are for what you SEE on the screen of your TV or other viewing device.
The RED/WHITE connectors are for what your ears will hear, LEFT/RIGHT in stereo or mono.
Now all you need to do is connect the YELLOW output jack of your Coby to the YELLOW video
input jack on TV. You must remember forever and ever that the YELLOW jacks and plugs never
contain or transmit or move TV channels or CABLE channels or DISH channels. The YELLOW cable
which has plugs at both ends goes to jacks (output to input) and carries/transmits BASEBAND VIDEO signals only. Now all you need to do is make the TV stop listening to it's antenna in, and to
start listening to the YELLOW/RED/WHITE jacks on the back of the TV. You will need find out how
to put TV into MONITOR mode, or AUX mode, or VIDEO INPUT 1. Basically just match colors and
OUTPUTS to INPUTS. Hope this helps you out.
louie12fix @ fixya
Dec 17, 2008 | Coby DVD-224 DVD Player
LOGICTECH X-530
That speaker equipment should've came with an adapter to audio cables
its a rectangle that has 3 ports (orange,black,green) that lead out to 2 ports (red,white) from there u need the audio cables or AV cables
connected the red/white prong to the red/white ports on the adapter.
then connect the other end to the back of the tv where you will c white yellow and red
for dvd player connect it to the white and red ports
dont wry about the yellow 1 that is for video
Oct 18, 2008 | Logitech X-530 Computer Speakers
How do i connect to my tv?
the yellow line is for the video the red and white is for the audio, and you can connect your DVD to your TV.
Oct 02, 2007 | Coby DVD-207 Portable DVD Player
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Samsung LN-S4692D 46 in. LCD HDTV Logo
215 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
