The DVR670 only works for about 6 months then errors out.
These units are JUNK. Dont waste your money on any Toshiba products. Their customer support sucks.
1) the batteries will be the same type and full charged
2) clean the contacts battery from dirty, dust, oxide or corrosion
3) retight the spring contacts battery with pliers for a GOOD contacts
4) open the remote.control and clean the keypads switch, from dirty, dust, oxide, Open contacts, or Bad contacts. they emite a good signal infrared from SYScon transmi vs Syscon receiver.
see the block diagram. If doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
SOURCE: MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
SOURCE: The remote to my RCA
You could try a universal remote (if one is available which will provide most functions to your player, such as STOP/PLAY etc.).
You can try a simple test on your existing RCA remote to see if it provides a 'frequency pulse'. Turn a radio on, select a black section of the AM band (not FM) turn volume up halfway, place remote near it, listen for pips and noises from the speaker(s) - if this occurs, the remote itself is OK. This is the cheapest idea to try first before going out and buying a new remote.
* If the unit does not respond to the universal (regardless of whether a
remote code is required or not) then the IRD within the unit itself and
its associated controller circuit may have failed (hence why the remote
does not work). Repair of this requires a qualified workshop technician (because of the many surface-mounted components in the IRD controller circuit). *
But try the original remote-to-AM-radio test and/or purchase a universal remote or similar if necessary.
SOURCE: We've been pleased with our
Hi, well no there are NO buttons controls or otherwise that can or will disable the unit,in the manner you describe..
What has most likely happened is that due to the lack of use, the unit has no doubt either a faulty sensor(s) or more likely the Mode Switch, these are the most commonest problems. Especially the Mode Switch, the contacts inside depend on use to keep them clean and making good contact, if not used for a while a tarnish builds up on the contacts and it will not make a good connection, thus it faults. You see when used, the action of being set and unset, burnishes the switch contacts in this special type of switch, and keeps them clean and working. Now the only way to "Fix" this if indeed I am correct, is by replacement of said component. I have seen this type of thing many times in my shop.
The repair, shouldn't be too expensive, say around $100 - $200.00? depending on things. However the advise i always give is to get the unit looked at by a professional and ONLY ask first for a "Quote" as to costings etc. Then at the least you can make up your mind as to repair or replace?
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a
Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
Repeat steps 1 through 5 for each device you want to control
OK
