Question about Toshiba Sattelite A105-S2071 Notebook
I have a Toshiba A105 Laptop, Screen goes blank after windows....
I have a Toshiba A105 laptop
when i boot it up it goes to the windows xp screen after that right before the starting up screen, it goes to a blank black screen with the mouse cursor. i can move the mouse cursor around, and at one point i let it sit there for 20 minutes to see if it would go past this point. it did not, so i turned it off and after several more tries it works but it doesnt.
  • jdguadalupe Dec 15, 2008
    I tried those 2 solutions but still did not work.
  • Anonymous Mar 25, 2014
    window7 goes black if no movement with mouse
    Sergeant:
  • 324 Answers
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Ron
Posted on Dec 15, 2008
  • Ron Roske Dec 15, 2008
    OK. Here is a more extensive list of what might be wrong.
    Lid closing switch getting stuck or becoming intermittent.
    1) Try
    manually operating lid switch during failure.
    2) Look
    for gunk, syrup or foreign material in the area of the switch.
    3) Carefully
    feel for proper operation of switch.
    Bad hard drive
    1) Reseat
    HD.
    2) Swap
    HD, preferably with new good.
    Bad memory Your memory (RAM) may need to be removed, and
    then put back in (reseated). The video
    shares the system's memory, and will not function if there is a problem.
    1) Reseat
    module(s).
    2) Swap
    module, preferably with known good.
    Check for dim display
    1) Try
    turning up intensity.
    2) Try
    going to a prior restore point.
    3) Replace
    inverter.
    Corrupted HD
    Recovery
    1) If
    you're doing a recovery and it doesn't work, make sure you've not got any PCMCIA
    cards, flash cards, USB thumb drives or anything else like that plugged in
    which aren't part of the original system.
    Best of luck!
    Ron
When I boot up my Toshiba A105 the monitor goes blank / black screen right after the Toshiba window. What is wrong with my laptop?
There is a video driver error, possibly just a corrupt file. Not easy to repair! You may need to reload your OS.
Try F8 as windows boots and select Safe Mode. If you can get in that way, restore your machine to a previously known good restore point.
Oct 06, 2012 | Toshiba Satellite A105-S4397 Laptop...
Hi, I have a Toshiba Satellite A105-S4254 when I boot the laptop it goes to the windows xp screen, after that right before the starting up screen, it goes to a blank black screen with the mouse cursor, but...
try restoring this unit to an earlier time
in restore function is a calandar check which things were updated last time
go to start
all programs
accessories
system tools
restore
heres the restore function
Apr 18, 2010 | Toshiba Satellite A105-S4254 Notebook
What can i do for my laptop, when i turn it on the XP splash screen displays, and then it just goes blank, no cursor, but it is still running
try booting into safe mode. hit the f8 key during bootup to get that option and see if safe mode works fine. If it does, then the problem is a bad or corrupt video driver. The display itself could be going bad, also, but that seems less likely if you can see the splash screen every time. If you cant boot into safe mode, you may have corrupt OS and need to do a repair install.
Oct 05, 2009 | Toshiba Satellite A105 Notebook
Laptop won't boot CD with HDD installed.
If it hangs with the new hard drive installed and doesn't without it hooked up then definitely the new hard drive is bad. Return it and get another one.
May 16, 2009 | Toshiba Satellite A105-S4164 Notebook
Blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
May 08, 2009 | Toshiba Satellite A105-S4384 Notebook
Display
If you've got exacttly the same each time you're start, then the VGA card has issue, or even the motherboard and CPU.
If not then try to chock the base of the screen with two fingers when starting, if nothing happen try to chock the middle of the keyboard and several spot around it. (it's a little bit brutal but the easiest way to find a bad contact or dead components)
If you feel like open it then this website will help you:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
and for the screen:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
good luck
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Blank screen
This might me cause of by two problems you need to check:
1 If you have genuine OS,and not expired.
2 your OS is corrupt, you need to repair (with OS disk) or reformat.
another secondary cause is due to malware or other virus infection which results in not displaying screen after bootup.
Try running in safe mode and run antivirus. or boot from OS disk to repair your windows.
Oct 18, 2008 | Toshiba Satellite A105 Notebook
Blank Screen
try to press fn and f5 probably the output was set to external video.
Jul 17, 2008 | Toshiba Satellite A105 Notebook
Toshiba Sattelite A105-S2071 Notebook Logo
987 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
