Question about Toto Carlyle 1-piece Elongated Bowl Toilet
After flushing, water does not refill the tank.
As there is no water refilling up the tank, is there an adjustment or valve that I can check that is stuck or faulty?
  • sunny2228 Jan 09, 2009
    My toilet will flush but i have to manually turn off the water to make sure that the water doesn't run all of the time. I checked the flapper and the seal is clean. The tank does not get more than about two inches of water in it. That is all the higher it will fill. The bowl has enough water in it. it is just that the water doesn't stop running...Can someone help
    Scholar:
  • 44 Answers
Yeah sounds as though the ball valve or water inlet valve is stuck in the closed position or jammed so when you flush the loo the water doesnt refill.
Isolate water service remove valve as required clean/replace re instate test & leave working
Posted on Dec 15, 2008
How do I increase the water flow into the tank of a Verona toilet
1.) Check to make sure that the water shut-off valve is all the way open (the water valve a.k.a. the shut-off valve is located behind the toilet near the wall or the floor, depending upon installation placement.) The water supply line attaches to it and feeds up into the refill valve assembly inside the toilet tank.
2.) Check the float assembly or the refill valve assembly, make sure it hasn't bound up by getting caught on another part inside the tank.
3.) Check the water level to make sure that it sits about 1 inch below the overflow tube in the middle of the tank. If the water is lower, adjust the float inside the tank to raise the water level. For models that have a ball float, turn the screw on top of the fill valve clockwise to raise the water level. For models that contain a cylinder float valve attached to the fill valve, squeeze the clip on the side of the float and pull the float up until the water reaches the desired level.
Feb 17, 2015 | Home
Tip
How to fix a refill valve
  • Brass-style toilet refill valves can often be repaired. To take a valve apart, remove the lever's screws. This allows you to lift out the float arm and valve plunger. Check the flat rubber washer on the end of the plunger. If it's worn, you can pull it out with pliers and either turn it around or replace it. This procedure usually corrects an overfilling problem. Next, reassemble the valve. If the tank continues to overfill, check to make sure the operating lever at the end of the float arm is functioning properly.
  • New refill valve. To replace the entire refill valve assembly, first turn off the water supply. The tank should then be flushed and sponged out, as detailed previously. Remove the inlet nut and riser tube from the bottom of the refill valve beneath the tank. Hold the refill valve inside the tank with a padded locking plier/wrench to keep it from turning, and remove the nut beneath the tank. With the nut off, the refill valve assembly can be lifted out and a new one inserted in its place. Follow the exact instructions included with the unit you purchase.
  • Finally, reconnect the riser tube and turn the water on. The tank should fill, allowing you to adjust the water level according to the instructions that were included with the valve.
  • Anti-siphon valves. The best refill valves offer anti-siphon protection. In fact, this may be a requirement. This protection prevents back siphonage of toilet tank water into your home's potable water supply system if a vacuum occurs in the toilet's water supply system. Whether or not this is a code requirement, the anti-siphon valve is a good idea to protect your family and public health.
on Jan 16, 2010 | Plumbing
Tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 | Plumbing
    Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
    That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
    Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
    WASH YOUR HANDS THOROUGHLY afterwards.
    Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
    After flushing the toilet with the fluidmaster 300 installed, and during the tank refill, the refill valve emits an extremely high pitched squeal until just a second or two prior to the tank being...
    hiya:) This is a result of a very minor design error (i am a big fan of FluidMaster products) combined w/a slightly higher than normal water pressure situation or foreign matter stuck in the valve somewhere. try turning down the water pressure via the shuttoff under the toilet tank:)
    Jul 26, 2011 | Home
    When the tank refills, the amount of water that is
    The fill level can be adjusted by either lowering the filler valve column or bending the filler arm down. The adjustment method is dependent on the type of filler valve. Be cautious not to allow the fill level to go above the designated fill line.
    Jun 21, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
    My dual flush toilet fills up slowly how do i fix
    Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
    Hope this helps!
    Nov 08, 2009 | Home
    Pegasus toilet tank will not refill
    Most likely the washer came off and is stuck in the shut off valve or the float is stuck all the way up. Checkk adjustment screw in the top of the water control valve to make sure it is not turned all the way in.
    Sep 26, 2009 | Pegasus Technologies Elongated 2 Piece...
    Tank wont refill after flushing.
    The ball **** controls the water flow into the tank when flushed. If the float is stuck in the up position, the water will not fill the tank or the valve could be defective. If after pushing down the float and observing little or no water you need to replace the ball **** or the water valve is turned off. Turn the water off at the shutoff valve. Put a towel under the water supply hose and unscrew the water supply hose at the bottom of the ball ****. Drain any excess water at the bottom of the tank using a shop towel or paper towels ringing them out when they become saturated with water. Remove the ball **** and replace the old one with a new one available from a hardware store. Make sure to follow instructions on washer placement to avoid leaks. Replace the water supply hose and tighten snugly and be careful not to over tighten to crack any plastic. Turn on the water shutoff valve and adjust the float so the water stops at the tank water line.
    Sep 07, 2009 | Kohler Home
    Solis Palazzo - stuck in descale mode?
    Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
    Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
    Toto Carlyle 1-piece Elongated Bowl Toilet Logo
    807 people viewed this question
    Top Toto Home Experts
    john h
    Robert McCall
    Robert McCall
    Mike
    Are you a Toto Home Expert? Answer questions, earn points and help others
