Question about Intel SE7501WV2 Motherboard
Hopefully you can help
Alright I finally got my SE7501WV2SCSI built the problem is now as soon as I plug the power cord into the back of the power supply the server powers on (PS fans, CPU's on full tilt) then the system shuts off and then same thing as above and then shuts off. At this time four of the backplane lights go amber during this process. They are DS2A1, DS3A1, DS3A2, DS3A3 while it is power cycling I receive no video display. This system is built in a 4U chassis and has 2x512MB of Micron RAM (MT18VDDT6472DG) and 2x2.66GHz Intel Xeon processors (BX80532KE2667D) and a FSB 500 Watt w/PFC (AX500-A). Any help or suggestions to get this server online would be great. Also I have removed the RAM and received the same problem if pictures are needed of the server board not a problem. Any more information required just ask. B
    Sergeant:
    Champion:
  • 293 Answers
Try to unplug all the power from the motherboard to the power supply for a few minutes and then plug it back. and try again ......
Posted on Mar 25, 2007
Sony Bravia built in DVD player wont accept the discs - why is this?
Performing a power reset
1. Turn off the television.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
How to establish an HDMI connection between a TV and other device.
Follow the steps below if the HDMI® connection between your TV and other device is not working:
1. Make sure both the TV and other device are turned on.
2. While turned on, unplug the power cords for the TV and device from the electrical outlet.
3. Disconnect the HDMI cables from the TV and other product.
4. Wait 60 seconds.
5. While the HDMI cables are disconnected, plug the power cords back into the electrical outlet.
6. Turn on the TV.
7. Re-connect the HDMI cables.
8. Turn on the HDMI-connected product.
The TV should now detect the HDMI signal from the connected device and operate normally. If there is still a problem, disconnect the HDMI cable from both products and then reconnect it in the opposite direction. In some situations this has been reported to resolve connection issues.
How to reset a TV to factory settings: https://us.en.kb.sony.com/app/answers/detail/a_id/61396
Hopefully this post helps you! If does, please mark it "accept as solution"
Aug 20, 2017 | Sony Televison & Video
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
With the unit unplugged remove the machine compartment and visually inspect for and burnt marks or frayed wiring. if non is seen, remove the wiring connectors from one component at a time and re test by plugging the unit back in. This will help you isolate the issue hopefully.
The machine compartment is on the back and the power cord is attached behind it. It is usually connected with 1/4" screws so a socket or nut driver will help you gain access.
Apr 22, 2014 | Refrigerators
Error 6500 displayed on screen already tried holding ON button for 10 secs .. released and pressed for another 10 ... printer resets but as soon as the wifi kicks in within the starting cycle same error...
Hello! Welcome to FixYa
First try this to solve error 6500:
Firstly Reset the printer and
Turn the printer off with the Power button then disconnect the data cable from the printer.Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Turn the printer on. If this works you have solved the problem If this not works then try the next step:
After confirming that the printer is powered on,open the paper output tray and Open the top cover and wait until the print head moves to the center then Open the inner cover and check that ink tanks are properly seated.Press down on each ink tank until a click is heard.Close the inner cover and top cover. Also do you have any kind of data equipment like a camera connected, if so this could be causing the problem as well. Unplug it if so and see if there is still the problem after the above steps then final & best option is to take it back where you purchased it or contact Canon service center about the error code.They will surely solve it.
I hope this solution was helpful for you.
Don't hesitate to let me know if you want any further assistance
Thank you for using FixYa, Keep visiting!
Sep 11, 2011 | Canon PIXMA MX340 Wireless Office...
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
Mesaage shows "Paper Jam" when I hit OK it pushes paper out but nothing prints. I pulled some paper from front to clear it and now I can not get it to print. Do I need a new one or is there a solution??
You can try following steps.
Press the Power button only once while the Printer is Powered ON, this will remove if there is any stuck paper.
Then
Unplug the power cord and press and hold the Power/ON button on the printer for 30 seconds and plug in the power cord.
If the issue still persists, perform the final reset
Please remove the power cable from the back of the printer.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
We have to press the keys on the printer. Release the buttons as soon as the power cable gets inserted to the printer.
If the issue remains there, contact HP for Upgrade
Jun 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
When attempting to copy, the printer first says WARMING UP and then indicates SCANNER FAILURE
This is a severe hardware issue.
In order to resolve the issue, make sure that the power cable is connected direclty to the wall socket.
If the issue still persists, perform the final reset.
Jun 02, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
My maytag dryer model HYE346OAZW is not working at all no light comes on no timer no heat, nothing
I would suggest checking the breaker first. You might want to turn breaker to off and back to on if it does not look like it has tripped. I have seen them trip but not all the way to off. If breaker has not tripped I would check to make sure the power cord is plugged in completely and is not loose in the back of the dryer. If cord is alright then there is a possibility of an internal fuse that could have blown. Hope this helps.
Dec 05, 2009 | Washing Machines
I cannot get the printer cartridge to go to the left so I can take the cartridge out to replace. On-off green light keeps blinking - help!
unplug power cord, press power button and plug the power cord. do not release the power button. press resume button twice then release the power button.
turn off the printer.
turn it back on hopefully it will solve the problem
Oct 04, 2009 | Canon PIXMA iP1600 Printer
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Jan 03, 2009 | HP Compaq Presario C304NR Notebook
Pro Scan doesn't power up
Pro Scan/RCA TV's (Pro Scan's are just glorified RCA's TV's) don't hold up very well (cheap components). You can try removing the back and checking the fuse/fuses (could be that simple), but if it's over 5 years old? You may be looking for a new TV soon.
You should find a fuse on the circuit board near where the power cord goes into the back.
I hope this helps, and Good Luck.
Mar 04, 2008 | Proscan PS35660 TV
Intel SE7501WV2 Motherboard Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
