Question about Dewalt Chop Saw D28700
My Dewalt chopsaw is loosing power and sparks heavy in brushes
I took the whole thing apart and blew it all out w, high air pressure air then with 600 grit sand paper I clean up the armature and then the actual brushes them selves. It seemed to of helped but I think that maybe moisture in the brushes could be the problem but not sure.
What could be the problem or what is the problem?
    President:
  • Dewalt Master
  • 1,388 Answers
I worked at a tool rental center while attending college and learned to repair tools such as yours. Damage to the armature occurs mostly during low power situations or overloading the motor. The damage is usually visable. Notice burned looking copper windings or commutator bars. You can test with growler or meter. We would turn the commutator on an armature lathe to true the surface of the bars. If the commutator is not perfectly round the brushes will bounce thus cause the sparking that you see. Also you must clean the groves between the bars with a blade to clean out all metal filings that can cause short between bars. (Broken hacksaw blade ground to fit the groves will work fine)Sanding with sandpaper may not be perfect enough to stop sparking assuming the armature is not shorted. Moisture will not effect the brushes, and sanding them square is ok but you can put the curve back by cutting fine sandpaper into strip and wraping it around commutator and insert brush into holder against sandpaper. Not necessary thou because all new brushes are square. New brushes however will increase the tension of the brush against the commutator preventing bounce due to new spring and longer carbon. Good luck enjoy
Posted on Dec 18, 2008
  • 2,176 Answers
If it sparking heavily usually that indicates a brush or armature problem. I think after looking at the armature windings for cuts in the wire that I would replace the brushes. Sanding them takes the curve out and they can't seat on the commutator properly.
Posted on Dec 16, 2008
Dewalt chop saw blows breaker after a few minutes of use. Bearings bushes and armature ae good. Is the gear box dragging so much that it powers off and blows the circuit breaker? Where in San Antonio, Texas can I have it fixed or where can I locate parts to it? Thanks, Romeo
Posted on Jul 28, 2009
How do you replace DeWALT D55154 electric motor brushes?
That model does not have brushes. You can see the parts diagram with this link.
Detail
May 25, 2014 | Dewalt D55154 Heavy-Duty Continuous 4...
Dewalt DW718 Sparks When cutting . just bought it
The people from Lowes were right.
There are two types of motor designs: Induction motors and brush-type motors.
All electric motors that have brushes make sparks where the brushes contact the rotating commutator. They also run less efficiently but they are a bit smaller than induction motors for equal power output. Brushed motors can also deliver greater power at initial startup.
Because the sparks in brushed motors create heat, the housing around the motors typically have ventilation slots for air to go through to keep the commutator cool. This means you are likely to see the sparks if you look in the right place.
Since it's more difficult to get an induction motor turning, they typically have a "start capacitor" mounted on the side of the motor to give an extra kick to get the stator turning. While induction motors use less power when running, the amperage they use at start-up is typically double the running amperage.
Sep 09, 2013 | Dewalt 12" Beveling Sliding Compound Miter...
Brushes heavy sparking
if brush and spring are in good shape you have a major problem;
spark on 1 brush : stator are bad
spark on 2 brush: check both rotor and stator for damage
Dec 31, 2011 | Dewalt Chop Saw D28700
The compressor motor is getting hot, I removed the cover and one of the brushes is shooting sparks when the motor is turned on, the brushes seem to have plenty of pad left and seem to be aligned properly...
If there were a problen with the field or the armature, both brushes would make fire(look at both sides of each brush for spark). Sparking is normal, however heavy blue fire would indicate problem. When one brush is making unusual sparks I would suspect that the spring applying pressure to the brush against the armature has failed. Look at both brush springs and see if there is a color difference or feel the pressure that the springs are exerting. They should be equal. You can push on the brush slightly with wood or plastic tool. To see if there is an improvement. Replace parts as needed. Test the motor with amp meter and compare to amp rating on plate to be sure that there is not a problem with motor. If amp draw is slighly high, check for tight bearing, leaking head gaskets/reed valves or leaking checkvalve at the tank. Good luck.
Sep 09, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
My Dewalt chopsaw is about 10 years old, and quit working.So I Took the brushes out and put them back in. It worked for a day, then it would hesitate, then it died. I tried new generic brushes,but the new...
If you can get your hands on a continuity tester, do a continuity check from the plug through the flex ,the switch, armature and back to the plug .It should be possible by a process of elimination to discover where the break is in the circuit.
It might be simply that there is a break in the cable where it exits the mains plug or where it enters the chop saw
Aug 30, 2010 | Dewalt Chop Saw D28700
My Dewalt 2 hp air compressor will pressurize, but not let pressure out to tools. tried new hose. problem seems to be near pressure regulator/coupler area.
Yea, there is a blockage there. maybe regulator bad. Take it apart after draining tank of air. And look for blockage of some kind.
Jun 05, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
I have a 20'' dewalt scroll saw that will not start
If you are getting voltage then it is most likely the control board. You would need to take it into a repair service center and they would have to pull the whole thing down to repair.
Jan 20, 2009 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Nailer leaking air
Same situation here with the same model.  Turned out to be lack of pressure coming from the air compressor.  I turned up the pressure a little and things went fine afterwards.
Nov 23, 2008 | Dewalt D51825 Heavy Duty 31 Degree Clipped...
Dewalt Chop Saw D28700 Logo
3,803 people viewed this question
Top Dewalt Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Dewalt Welding Tool Expert? Answer questions, earn points and help others
