Question about Canon NP 6050 Copier
NP6050 false paper jam
Thanks for the response. You're description of the problem was spot on. The tray drops slightly, and then the jammed message appears. I tried your suggested fix, unscrewing the top tray and unplugging the connector but to no avail. I may be on the wrong connector though. There was only one attached to the paper tray as I removed it so that's the one I unplugged. Any other ideas?
  • Canon Expert
  • 1,326 Answers
Can you see the paper pick-up rollers try to move and pick-up the paper? Or can you hear it make noise? Also, is the problem in paper tray 1? You may have to adjust or reform a inter lock arm on the right side door. If you push the back part of the right top door closer, will it feed the paper? If so there is adjustments for the door and look for a bent Tab on the hing part of the top door about half way up. Just a note have the paper pick-up & paper feed and paper sep rollers been replaced?
Posted on Dec 28, 2008
Hi! I have a LaserJet Pro MFP 476nw. When I go to print an envelope using the automatic envelope feeder in the front drop down door, I get the message Clear jam in tray 2.
Go to your menu and pick that cassette out and make sure it is set to the proper size envelope. ten to one it is not os it shows a jam cause it is looking for another size.
Mar 27, 2018 | HP LaserJet Office Equipment & Supplies
I have a Samsung Printer Model SCX4100. I had a paper jam and removed the paper, however, I Have a Paper jam 2 Message and don't know how to clear it. Please tell me what I need to do to clear the...
This is a sample guide;
41093dd.jpgWell I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
Hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Samsung Office Equipment & Supplies
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Paper jam warning icon flashes but there is no paper jam.
Well I would take a can of air and blow off the sensors, especially where you began to have problems. The sensors (over time) become coated with paper dust and now reflect back on themselves thinking there is paper there all them time. From your description of the problem, it seems like the issue-intermitten jams/intermitten false jams, until a total false jam.
Apr 17, 2009 | Xerox 8830 Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Jamming at the registration
Does it jam at the paper guides before the reg. rollers? Did you replace the reg. clutch? Also, dose it happen only with the LTR size only? Due the bottom 2 trays work & the by-pass? Also, have you made sure the OPC screw is tight? I think that it may be that your paper guides may be bent in-ward, by accident when unit one was removed.... I've done it a few times. Also, did you have the same problem before? Did you test the sensor and flag? It could also be a sepperation problem. You never said where it is stopping, at what exact spot is it stopping at?? Gave you a few ideas.... Get back to us with more info.
Sep 29, 2008 | Canon NP 6050 Copier
False paper jam message
PRINTER TRY TO PICKUP THE PAPER,BUT PRINTER CAN'T.THE CAUSE OF THIS ERROOR IS FAULTY PICKUP ROLLER & SEPRETION PAD.SOME TIMES PAPER TRAY CAN NOT BE OPEN WHEN WE PUSH IN,IN THIS CASE PRINTER SHOWS PAPER JAM
VIJAY THAKUR
Jul 01, 2008 | HP LaserJet 2430dtn Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Canon NP 6050 Copier Logo
106 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
