Question about LaCie mini (300998U) 250 GB Hard Drive
Hubs don't work on LaCie minin 250 GB Hard Drive
I purchased a LaCie mini 250 GB Hard Drive at the Apple Store because my hard drive on my i-Mac OS X 10.3.9 (Processor:800 MHz PowerPC G4; Memory 768 MB SDRAM) was getting full. My iMac doesn't have a lot of USB or Firewire ports so I chose the LaCie for not only the space but for the hubs, too. The hard drive works great but the hubs don't work at all. Examples: When I plug in my Canon PowerShot S50 it doesn't launch iPhoto and I can't download photos to the computer unless I connect the camera into my computer or keyboard. When I connect my iPod shuffle to the Lacie it doesn't bring up iTunes and it won't connect to the computer. I have to plug the iPod shuffle directly into the computer for it to work. I also tried to connect my keyboard and mouse into the Lacie just to see if they would work, they don't. I went to Apple's site to read about all the things you can connect to the LaCie mini 250 GB Hard Drive. Here's how they describe it: "With four USB-powered hub ports and two FireWire-powered hub ports, you can extend the capability of your computer; double or triple its power or even more with seemingly endless expansion possibilities. Thanks to the mini Hard Drive & HUB, you can connect all of your hardware peripherals at once like your iSight, iPod, mouse, keyboard, camera, video recorder, speakers and other hard drives. Even use the USB ports as a hub when the drive is connected to the host via FireWire." That's about it. Any ideas? Please help! Thanks!
    Novelist:
    Scholar:
  • 158 Answers
There is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Posted on Aug 14, 2007
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
Unable to access space on Lacie remote drive
The easiest way will be to format the disk drive. Highlight the icon, right click and format.
Feb 07, 2010 | LaCie (300770) 250 GB Hard Drive
Will erasing my LaCie ext HD impact any files on my Mac Book?
It will only effect thoes stores on the external harddrive. You will have to check the contents of the LaCie drive and see if it has any files you typically access from your Mac Book. Other then that no it will not effect files stored on your Mac Books drive.
Jan 06, 2010 | LaCie (300728U) 250 GB Hard Drive
Lacie 250 GB (Neil Poulton) external hard drive not recognised on PS3 (20 GB) . My friend has a Maxtor 250 GB drive, he can play just about anything from his drive on the PS3, but i cannot. The drive does...
go in to add new hardware in control panel and run external drive ere from there use disc if u have one or go to vendor's support page and download driver's from there
Jul 18, 2009 | LaCie (300770) 250 GB Hard Drive
Hard drive does not always appear (mount?) on my desktop (Mac) I hear humming sound from inside. Has been going on for at least 6 months with increasing frequency. Is happening more than 50% of time now. 2...
Your hard drive is toast. If the computer doesn't recognize the hard drive and/or you hear a constant turning sound then your drive is broken and can't be repaired. You'll have to have it replaced.
Aren't you glad you backed up everything?
Jul 09, 2009 | LaCie (300728U) 250 GB Hard Drive
Partitioning lacie hard disk 2.0 500 gb
Windows XP: Right-click on "My Computer" and select "Manage". From there, select "Disk Management" which lets you view the drives and do things to. More details here...
If you're on Mac OS: Here's how
Mar 20, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
Search Problem
This was a Mac OS issue. The Volume needs to be Re-indexed:
  1. From the Apple menu, choose System Preferences.
  2. Click Spotlight.
  3. Click the Privacy tab.
  4. Drag a folder or even an entire volume (your hard drive) to the list.
  5. Remove the item or volume you just added.
Spotlight will re-index the contents of the item you initially dragged to the list.
Feb 08, 2009 | LaCie (300728U) 250 GB Hard Drive
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
Oct 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie drive
I got the same problem mate, im going to a computer store tomorrow and found out what to do , ill email you first thing tomorrow avo when i find out
Mar 22, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie mini (300998U) 250 GB Hard Drive Logo
236 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
