Question about Reddy Heater-30-55,000 BTU Variable
Not getting fuel
Hi again,
i finally got back to my heater.the photo cell was clear,but i did wipe it with the tip of a clean rag.the fuel tank seems to not be drawing up the fuel in the line.could this be related to something else?its getting cold in texas and i would love to get this thing going.thanks in advance
  • 232 Answers
You must take a reading of the air pump. The air pump pumps air to the nozzle and also sucks fuel from the tank. Don't take the pump pressure lightly.
How to set the pump pressure
Posted on Dec 15, 2008
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
The heater will not light the kerosene starts then the ignitor lights then shuts off I tried repeatedlyto fire it no luck I think it might be an air adjustment
Here is the manual that will help you sort it out.
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
I think you have a photo cell or fuel issue as it ignitor trips but you do not get fuel.
Make sure you check the seal in the tank cap (Closed tightly) and the 2 hoses from the tank for cracks. The fuel system works via the 2 tubes. One is pressure the 2nd is fuel supply. Any leaks via either hose or the fuel cap will prevent fuel flow.
You may have to clean the fuel nozzle also. Just make sure to clean the photo cell carefully before putting it back together.
Unless you have an air filter(s) that is horribly clogged taking care of the above should get you going again.
Thanks for choosing FixYa,
Kelly
Jan 28, 2011 | Master Heaters Master B115DT 115,000BTU...
Ignites /starts will cut out after a few minutes
There are several reasons as to why this happens, and with that being said there are several things to correct this problem. I do this as preventative maintenance, remove the top section of the burner tube, this exposes the entire burner tray and internal parts. Locate the nozzle and remove it, they say you can not clean these, I say with a Q-tip, tooth pick and carb cleaner you can with out damaging it. Now behind the nozzle is a screen assembly these corrode at times so make sure to clean it as well.After cleaning up assemblies put the nozzle and filter screen back together.Next is the flame sensor, it is located below the nozzle assembly, round in shape and has a lens of sorts at the front. These collect carbon deposits, dirt, and the occasional homeless insect. It can be cleaned with a soft terry cloth rag and windex, now inspect the fuel lines for cracks, holes, or dry rot, replace if necessary. Locate the fuel pump next, on the back of it there is a foam air filter, this I clean with dawn dish soap rinse and dry really good, then put it back. Trace the fuel lines back to where they come thru the burner tube, now remove the side cover, you should see the fuel line and it goes to an in line filter. Remove the filter and I use a compressor and blow gun to clean it by blowing air backwards thru the filter, instantly clean. Inspect your lines again, replace if necessary. Replace side cover and open the fuel tank, lean the heater so the fuel runs towards the fuel filler opening. You are looking to see if water is in the tank, this happens from condensation when in storage. If there is I drain the fuel in to a clean five gallon bucket, now the fuel will float on top of the water and you should be able to see it.If there is water try to dry out the tank with a rag and remove as much water as you can. You can siphon off the fuel from the water and reuse it if you like just be careful not to siphon to far and get the water. Fill your heater with fuel, put cover back on the heater and plug it in, it should now fire up like new. Good luck
Dec 29, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I have a all pro R60A that turns on but shuts right off and blows tons of smoke out after shutting off.
These heaters have several things that happen to them while in storage. I do a yearly check on mine and it goes like this. Open the fuel tank and tilt the heater to see fuel at the filler hole, look at the fuel and tank you are looking for any water in the tank. Condensation is usually the culprit, what I do is drain the tank in to a clean five gallon bucket and the fuel floats on top of the water. If you see water use a rag and try to dry out the tank as best as you can. You can also siphon off the fuel for reuse just be careful not to siphon to much and get the water again. Next remove the top section of the heater tube, this exposes all of the internal burner parts. Locate the burner tray and remove it so you can access the fuel nozzle. Remove the nozzle, they say you cannot clean these but I say different. You need a Q-tip, tooth pick and carb cleaner and clean it up carefully so you do not damage the nozzle. Behind the nozzle is a screen these like to corrode so clean it real good too. Put the nozzle assembly back together, inspect your fuel lines for cracks, dry rot or holes and replace if necessary. At the bottom of the assembly there is a sensor for flame these collect carbon deposits,dirt and the occasional homeless insect. Clean this with windex and a soft terry cloth rag. Put the burner tray back together. Trace the fuel lines back to where they come thru the heater tube and now remove the side cover. You will find the fuel line and an in line filter remove the filter and clean this with a compressor and blow gun by blowing air backwards thru the filter. This instantly cleans the filter, now put it back together after inspecting the fuel lines,and replacing it if necessary. Put the side cover back on and go to the fuel/ air pump on the back of this there should be an air filter usually foam, clean this with dawn dish soap and dry really good before putting it back in.Inspect and clean igniter while you are inside the heater, then put the top section back together. Now you are ready to plug your heater back in and test it. If all went well you should be heating like it did when it was new. Just a tip for you is to look at the fuel coming out the nozzle it should be a fog not droplets, if droplets your nozzle needs changed. Pay attention to spray angle and GPH rating very very important.
Gas heater keeps cutting off every few minutes
These heaters require some yearly maintenance and here is what I want you to do. First look in your fuel tank and tilt the heater so the fuel moves towards the fuel cap or inlet to the tank. You are looking to see if there is water in your tank, and this does happen by condensation forming while in storage. If there is water in the tank drain it all the way and dry the tank with a rag thru the filler hole. I empty mine in to a five gallon bucket and check it out. This way you can siphon off the fuel and reuse it, water is heavier and will sink to the bottom. Now yearly maintenance is as follows, remove the top half of the heater cover, locate the burner tray, remove it partially to expose the fuel nozzle. Remove the nozzle, they say you can not clean nozzles, I say with a q-tip, tooth pick and some carb cleaner you can just be careful not to damage the nozzle. Behind the nozzle is a screen these corrode too so clean it up as well, put the nozzle and screen back together and locate the flame sensor, these collect carbon, dirt, and occasional insect looking to nest. Clean this with windex and soft terry cloth rag, in putting this back make sure it has a clear unobstructed view of the flame. Inspect the fuel lines for breaks, holes and dry rot, trace them down to where they come up from the bottom. Remove the side panel and locate the fuel line and remove it from the in line filter. To clean the filter you need a compressor and blow gun then you will blow air thru the filter backwards and now it is instantly clean.Now put the heater back together, side cover,and top. You are now ready to start the heater up so, add fuel and electric you should now be heating like new. Good luck
Dec 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I have Reddy Heater 155 Pro. I fired up yesterday for the first time in months. I put in fuel, but this morning It sparks to fire, but will not light. but it appears to have fuel blowing out. It will not...
This morning I had an identical problem with a new heater, the culprit ended up being the fuel tank had water down inside it. Condensation causes this when you store them. I ended up draining it in to a five gallon bucket and then watched the water separate and go to the bottom of the bucket. Needless to say cleaning out the tank was real fun, after draining it I stuffed rags down in the tank to **** up the water, siphoned off the fuel from the water with an electric pump and filled the heater up now it is working fine. Remove the top cover and check the burning tray over real good, I would clean the flame sensor with windex and soft terry cloth rag. Then pull some preventative maintenance, locate the nozzle, remove it, nwo they say that you can not clean these but I say with a q-tip, carb cleaner,and a tooth pick you can with out damaging the nozzle. Directly behind the nozzle is a screen clean this as well, now put it back together. Inspect all fuel lines for holes, dry rot and cracks, if all is good move on to the side cover where the fuel line goes thru to the fuel tank. Remove it and locate the fuel line and filter, remove the filter and clean with compressed air and a blow gun, blowing air backwards thru the filter, instantly clean. Now put it back together and inspect lines again. On the back of the fuel pump is a foam filter for air intake remove it and clean with dish soap and water, be sure to dry really good then put it back and button your heater back up. Now you are ready for testing and happy heating.
Dec 23, 2010 | Reddy R155D Utility Heater
I have a 55,000 BTU Reddy Heater that runs on K-1 Kerosene. I used it several weeks ago and it seemed to stik far more than usual. I tried to used it yesterday and now it seems to come on for a second...
Water in the fuel tank, I personally had this problem this morning irritating but was simple to cure. Empty your fuel in to a clean five gallon bucket and observe, fuel is lighter than water and will float on top water settles to the bottom. You now have to dry out the tank, get creative I stuffed mine with rags and sopped it all up, this worked fine for me. You can siphon off the fuel from the water and re-use the fuel. Just be careful not to siphon off the water with it.
Dec 23, 2010 | Reddy Heating & Cooling
Torpedo heater shuts off after several minuets, will not start again 5-6 minuets
These heaters require some preventative maintenance from year to year and here is my routine. There is a flame sensor in the burning tray, these collect carbon deposits, dust and dirt, and occasional insect nesting area. Locate the flame sensor by removing the top half of the heater, now remove it and clean with windex and soft terry cloth rag. Replace sensor and be sure it has an unobstructed view of the flame. Fuel is next, with the top still off locate the fuel nozzle, remove it and the say you can not clean these but I find that carb cleaner, q-tips and a tooth pick work just fine to clean them. Now when you remove the nozzle there is a screen filter directly behind it, these can corrode over storage so clean it too. Now inspect fuel lines for cracks, holes and dry rot. Put fuel system back together and the top on. The fuel line comes down thru the side panel and thru a filter then in to the tank. Remove side panel, locate fuel line, remove the filter and clean with a compressor and air gun. Blowing air thru the filter backwards will clean these right out. Put it back in line, put side panel back together. Next is the air filter on the inlet of the pump, they are foam. Clean this and dry it real good then put it back. Really look in the fuel tank to make sure you have no water,rust, or any other contaminants in the tank, fill with new fuel and you are ready for heat. Sounds complicated but really isn't, take your time and in an hour you will have this heater running like new.Good Luck
Dec 23, 2010 | Dayton E50 Heater
My heater keeps shutting off after about 30 seconds. I hit the reset button and it happens again. Any thoughts or suggestions?
Several thoughts on this heater Fuel delivery system, the fire eye sensor or dirty intake filter. These are the most common problems that I run in to with these heaters. Start by taking off the top half of the heater tube. Find the nozzle unscrew it and clean the screen in behind the nozzle, inspect the nozzle for corrosion or damage. If you see any restriction replace the nozzle pay attention to spray angle and GPH rating this is printed on the nozzle. They say you should not clean the nozzle because you can damage them, well carb cleaner q-tips and a tooth pick seem to work well and not cause damage. Locate the flame sensor these get a dirty lens and can shut down heaters as well. Try cleaning with windex and soft terry cloth rag, works wonderful.Back to fuel system inspect the fuel line look for holes dry rot or restrictions.Remove the screws on the side cover to expose the wiring and fuel line with filter to fuel tank. Remove the filter and clean it I use compressor and an air blow gun and blow backwards thru the filter cleans it right out.Inspect it and the lines reassemble and at the back opf the heater is a sponge type filter remove it. This is a foam filter wash it out, dry it real good put it back in and fire it up. Take your time pay attention to detail and this should help your ailing heater.
Dec 21, 2010 | Dayton E50 Heater
Kerosene Portable Forced Air heater comes on, runs awhile
The unit should have a fuel & air filter. Check that both are clear. Inside the burner tube, there will be a photo-cell, if the lense is dirty it will shut the flame off. The photo-cell needs to see the flame. You can carefully and gently, clean the lens with a tissue, soft cloth, or Q-tip. Please let me know how its coming along.
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Reddy Heater-30-55,000 BTU Variable Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
