Question about HP Photosmart C6280 Printer
Hp c2680 printing coppies.
I am using blank copy paper and a error message keeps saying load paper face down in main tray.
Help.
SOURCE: Error message: load paper face down in main tray
Here is a reply from HP about this error. The "Semifull Reset" seems to work for me so far.
Tony H.
I am Munik from HP Total care for All-in-One products and this is my response to you in regards to the query related to HP Photosmart C5180 All-in-One. Thank you for contacting HP Total Care and its a great pleasure for me to assist you.
I understand from your e-mail that your printer makes a lot of noise when it tries to print and also gives the following error message "Out of Paper Load paper face down in Main Tray", I regret for the inconvenience and apologize for the same.
To isolate the issue, I recomemnd you to refer this website and ensure the correct paper load:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00704348
Copy the URL from "http" to "c00704348", paste it in the address bar of the browser and then press Enter.
And now to resolve the issue, I request you to perform the following website:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=c00786157
Copy the URL from "http" to "c00786157", paste it in the address bar of the browser and then press Enter.
Now check the status, if the issue persist then perform teh following steps:
I. Power cycle
Follow the steps below to power cycle your all-in-one:
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
II. Semifull Reset:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
I believe the above information helps you. If the issue persists, please get back to us with the results. We will be glad to assist you.
We appreciate you giving us the opportunity to provide you with superior customer service. I wish to take this opportunity to thank you for being one of our most valuable customers.
Have a nice time.
Sincerely,
Munik
HP Total Care.
Posted on Jan 30, 2008
SOURCE: Paper won't load
I had a very similar problem and what had happened with mine is that there is a very small narrow brush that I think is there to clean the paper right before the print goes down and as I looked closely at the printing module (I don't know what else to call it, it's the part with the cartriges that moves back and forth to print) that brush (it has a sticky backside and attaches somewhere underneath) was out of place.  I think it was precluding the module from detecting the paper was there (I noticed a laser scan each time I would push the "ok" button on top).  I pulled that brush thing out and it started working right away.  I wasn't sure what the proper position of the brush is so I just threw it away.  It's printing fine now.
Posted on Oct 07, 2008
SOURCE: I have installed the HP
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Posted on Jan 13, 2009
  • 108 Answers
SOURCE: Paper jam message
check the paper tray to make sure paper goes up. Also check to see if there are any obstructions in the paper path.
Posted on Jul 31, 2009
Tinteiros
  • 85 Answers
SOURCE: My D7460 will not feed paper The screen says load
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Posted on Nov 02, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Printer won't pick up paper to print or copy. paper is loaded put registers as 'out of paper, load paper face down in main tray'. this has all been done. What's wrong
If it's in the 1st paper tray, pull out the tray and check if theres a sensor. Check if it's out of position, if it is, place it back in position. If the printer still says 'load paper' the sensor is most likely faulty.
Dec 18, 2015 | HP Photosmart C6100 All-In-One Printer
I am trying to print a document and it keeps telling me to load paper
Hi
Turn it off and disconnect it from PC and from power.Reboot the PC.
Connect the printer again and try to print.
Look through the paper tray for any obstructions.
Feb 21, 2012 | HP Photosmart C7280 Printer
Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Jan 06, 2011 | HP Photosmart C6280 Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
How to load paper
Your model has two trays on the front. The bottom one of these two is where you load the blank paper.
1. Raise the output tray to load paper into the main input tray.
2. Slide the paper-width guide to its outermost position.
3. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
• Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
• Make sure all the paper in the stack is the same size and type.
4. Insert the stack of paper into the main input tray with the short edge forward and the side to be printed down. Slide the stack of paper forward until it stops.
5. Slide the paper-width guide inward until it stops at the edge of the paper.
Do not overload the main input tray; make sure the stack of paper fits within the main input tray and is no higher than the top of the paper-width guide.
6. Lower the output tray.
7. Pull the output tray extender towards you, as far as it will go.
I hope this helps!
Dec 08, 2009 | HP Photosmart C5280 Printer
Pictures will not print and paper will not load for printing pict
You need to push the paper through just touching the boundary of the printer paper tray
Feb 12, 2009 | HP Photosmart D7260 Printer
Will not "Print" copies.
It may be that you are putting the page face down in the paper feeder when it needs to be face up or the other way around.
Jan 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Tony H.
I. Power cycle
II. Semifull Reset:
Note:
Have a nice time.
Sincerely,
Munik
HP Total Care.
Dec 12, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart C6280 Printer Logo
345 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
