Question about Solis Master 5000 Espresso Machine
Instruction manual for Solis Master5000 / digital
Hi
I have benn given a Solis Master5000 / digital unfortunately without an instruction manual Currently the language is set as German and I need the English setting. Not only do I need a manual but also is there a call centre that will talk me through changing the language setting?
many thanks
  • admin237 Mar 27, 2009
    Great thanks
Turn on the machine. Hold down the button that says steam/enter (the one below the blue button) until it says "Sprache" and "Wasserh.." . The cursor will be blinking beside Sprache. Use the down/up arrows (the large coffee and espresso cup buttons) to scroll until you find English. Hit 'enter' (steam/enter button) to set the language to English. Hit 'escape' (the tall coffee button) and your language should be set to English. You can also go to solis.ch and download a manual for your machine. Good Luck!
Posted on Dec 16, 2008
My Solis master 5000 leaks water from the removable water decante
Hi
On top of the machine under the water tank is a doughnut cover. Pry the cover up and it should pop off. There is a black seal in the center that will shrink over time with calcium and that just needs to be replaced. When you go to replace it it will not slip in. You need to run your finger nail around the bottom of the seal to get it in. Then it will push down. Flat part of the seal up.
Dec 12, 2009 | Solis Master 5000 Espresso Machine
Solis Master 5000 won't warm up
Hi
Sometimes when you first turn the machines on you need to run water through the wand to get them to start heating. If you have run water through the wand and it still won't heat up, you could have a bad board or sensor wire off, boiler wire off, bad element or thermostat.
Oct 19, 2009 | Solis Master 5000 Espresso Machine
Solis Master5000 no water or steam
Can you get hot water from the unit? If yes then the pump is working, next thing is have you tried to set the grind to the coarsest setting, if yes then there is a blockage in the line, try descaling the machine, if that does not fix it, you might have to open it up or send it into a repair center.
Apr 06, 2009 | Solis Master 5000 Espresso Machine
I have been given a camera Fuji FinePix S5000 without instruction
here is the link for download
It is a PDF file and you can print it.
Good luck
http://www.fuji.fi/documents/12/5000_manual.pdf
Mar 04, 2009 | Fuji FinePix S5000 Digital Camera
Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Aug 30, 2008 | Solis Palazzo Espresso Machine
I was given a Mustek Digital video DV4000 a couple of years back, but it came without a battery charger or instructions that were in English! I was wondering where I could find one? Thanks.
Hi - You can download the manual from the link below:
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 07, 2008 | Cameras
Solis Master 5000 Espresso Machine Logo
238 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
