Question about Sony VAIO VGN-FZ290E1 Notebook
SONY VAIO VGN-FZ290 DONT TURN ON ANYMORE
I WAS PLAYING MY GAMES WITHOUT THE BATTERY ON, JUST AC CABLE AND SUDENLY IT TURN OFF AND DID'T TURN ON ANYMORE,
  • 1 more comment
  • Anonymous Jan 17, 2009
    used to be overheated all the time but with enough air flow.
  • obed tamaca Mar 06, 2009
    HEY BELIEV IT OR NOT I SEND IT TO SONY REPAIR CENTER AND THEY GAME ME A REPAIR ESTIMATE OF $1737.97 WOW I CAN BUY 2 OF THIS WITH THE PRICE AND I REFUSED TO FIX IT, THEY SEND IT BACK TO ME AND BEFORE TO PUT IT IN THE WASTE CONTAINER I TASTE IT UP AGAIN AND IT DID TURN ON, SO THE PROBLEM NOW IS WITH THE HD BUT EVERYTHING ELSE IS WORKING IT MEANS SONY SUPPORT IS NOT THAT GOOD
  • HW_Dude
    HW_Dude May 11, 2010
    Is there a chance the VAIO was placed such it could not get sufficient airflow from underneath and overheated ? Was the unit hot in the lower left side of it ?
Hi everytime i open my vaio net book it wont open
Did you try just on battery power alone? Also try powering it up on AC
and the battery removed. When it turns on for a second, do you hear any
beeps?
99.9% of most laptops can run without
a battery.
Jul 11, 2010 | Sony VAIO VGN-AR630E Notebook
Hello experts, I am havig problems with my Sony VGN-Z56TG. When I start up my computer, the Sony Vaio Gate does not open or respond. Thanks, John
you dont here any sound or wont see anything on the screen?
try doing this..
  1. disconnect the computer from a power outlet
  2. remove the battery
  3. without the ac adapter and the battery, press and hold down the power button for 7-10secs to release static electicity
  4. put back the battery and ac adaptor then turn on the computer
hope this works.. ü
Mar 12, 2010 | Sony Computers & Internet
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Vaio notebook doesn't turn on after unexpected shutdown
hehe, i understand.. the repair is expensive
try this first
  1. disconnect the ac adapter and the battery
  2. reseat the RAM or memory if you can, if not, its ok
  3. without the ac adapter and battery, press and hold down the power button for 7-10 secs
  4. reconnect the ac adapter and the battery
  5. try turning it on again
hope this helps//
Feb 02, 2010 | Sony VAIO VGN-FW290JTB Notebook PC
Horizantal lines in screen with NVIDIA GeForce 8400 in sony VGN FZ290 laptop. Same problem even if booted with Linux live CD.
Check the pin cables going to and from the monitor and video board. Loose or brokem pin line will cause problem
Oct 13, 2009 | Sony VAIO VGN-FZ290E1 Notebook
Sony vaio vgn series doesn't turn on no power
You should try another ac adapter.If that does'nt work the power jack where it plugs in may be bad or the power board under the power button is bad.You should try another ac adapter first though.
Aug 04, 2009 | Computers & Internet
Sony Vaio VGN-FE550G Battery Power Probs.
sounds more likely you have blown part of the charging circuit when you have pulled the ac cord from the laptop
Jul 03, 2009 | Computers & Internet
Backup for Sony vaio
If you got the recovery disk along with the Vaio laptop, good enough.Insert the disk and reboot, follow instruction displayed on the screen to restore.
If you dont have a disk, can try this :--
Reboot and press F11 to try and enter the system recovery mode, if you can then you're good, simply follow the prompts to perform a system recovery.
Let me know the status please.
Thanks
Mar 30, 2009 | Sony VAIO PCV-RS710GX PC Desktop
Sony VAIO VGN-FZ290E1 Notebook Logo
158 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
