Question about Albatron GeForce MX4000 EL, (64 MB) Graphic Card
Dell Dimension 5100
I cant boot from CD, cd is set as first boot device, the disk starts up as though all is well then i get a message saying unable to boot from this device. the disk is good as it works on all other PCs its just this damn dell pc
  • swampy1979 Dec 16, 2008
    What I am trying to do is either replace some of my system files which needs to be done offline, or reinstall the OS but the only way I can do this is to boot from the BIOS with XP OS Disk or Bart PE from USB or Disk
    I have tried booting from USB too but again no joy, the device is there when XP is running so I know it works (I'm using the front USB connectors on front case).
    To boot from the USB drive, do I need to use the rear USB ports directly on the motherboard for it to be bootable in bios like a hard drive? (I'm not presently at the PC)
    Or is there any way to reset the BIOS without taking the PC to bits, to see if that would fix the issue
  • Frank
    Frank May 11, 2010
    what are you trying to do?
    are you reinstalling the OS?
    Genius:
  • 1,605 Answers
Press F12 when the BIOS startup.
it should give you a choice as to what drive you want to boot-off.
that also enable you to boot-off from USB.
Posted on Dec 17, 2008
    Problem Solver:
  • 19 Answers
Replace the CDROM, or boot from a USB device.
Posted on Dec 16, 2008
I need assist to reformat my system
Place your system disk in the CD/DVD Rom tray.
Power up the desktop and boot from the CD/DVD Rom.
Follow the prompts and use the Replace System choice in the menu.
If it won't boot from the DVD/CD Rom, Enter the BIOS menu and set the first boot device as CD/DVD Rom then try again.
When installed, download the latest drivers from Dell.com. That will ensure that you have the very latest tried and tested drivers.
Hope that helps.
Dec 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Unable to boot PC
link to external sources to help you stay safe (Avoid Internet fraud! ... must have an anti-spam filter that can block spam in double-byte ... But a little caution can go a long way towards avoiding malware exposure. ...... Windows 2000 server could not start because the following file is missing or corrupt: ...
Jul 13, 2010 | Dell Dimension 9100 PC Desktop
Shows no boot device run dianostics on harddrive _pass
If your computer cannot read from your disk-drive, then it will try to read from a disk inserted into the CD-drive.
So, it's likely that the disk-drive on your computer has died.
Take the computer to a qualified technician, to replace the disk-drive.
Mar 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 original partitions have been wiped .. Now need to reinstall xp . I can not. Selected boot device not available. can not do ctrl-f11 anymore of course btw just in case you were thinking...
If you are getting message the message "selected boot device not available" that is because you have do not have a bootable HDD (Hard Disk). Please do the following:
Insert the Windows XP Operating system Disk.
Restart the computer and start Tapping the F12 key, It will give you the boot options.
Select to boot from CD/DVD-Rom
When prompted press any key to boot from CD-Rom
Once the computer is booted from CD, follow the instructions to install the Operating system.
Note: You can also go to BIOS (by pressing F2 or Delete) and change the boot device to CD-ROM
Once you finish installing the Windows Operating system. You can go ahead with installation of your Linux Operating system. After you finish Installing Linux you will get the option in GRUB to select the Operating systems.
If you have already installed Linux and want to install the Windows, Follow the same procedure but it will directly boot Windows after you finish Installing Windows. You will have to write the GRUB again for your Linux system.
Please get back for any further assistance.
If you find this solution helpful, Please do not forget to rate it.
Thank you for choosing Fixya.
Nov 14, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My dell 5150 dimension will not boot up and says no boot device available. I have gone into system setup and tried a few things and at one point got a message that said drive 0 not found and now it is back...
Go back to setup and check your boot sequence. It may not be looking for your hard disk. Do you know what Hard disk you have? It may not be wired in there properly if it's in the boot sequence. Set DVD/CD to 1st boot device and put in your installation disk. Do you boot now? Do you have data on your hard disk you need? If not, Re-format the drive.
Nov 07, 2009 | Dell OptiPlex GX280 PC Desktop
Selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
Aug 10, 2009 | Dell Dimension 8400 PC Desktop
When I boot from a boot disk I am unable to change to another drive tells me each drivce is invalid. Also unable to boot from cd. I have 1) a drive (uncheck or check to turn off or on) 2)hard drive same...
Check the cabling between the drives. Make sure the BIOS sees your drives. Try swapping the ribbon cables between the drives and the motherboard. If you have to, disconnect each device and test them one at a time. This process should isolate the problem device. Make sure that the drives' jumper settings are correct, too (per cable if two devices, one master and one slave, or both devices set to cable select).
Mar 11, 2009 | Dell Dimension 4500 PC Desktop
Unable to restore to factory default. Boot up with 98 boot disk will not allow me to change to another drive. I am told that the operating syst is newer then what they gave me on the cd. I have gone to the...
go into the BIOS (Setup)(Should be F2, but look for the instruction on the DELL splash screen). Try to move the cd-rom up the list. The instructions should be on the screen somewhere, sometimes it is + to move up - to move down. It should say on the screen. Tthen save the settings and reboot. Let us know if it still does not boot from CD. You will have to hit a key when it says "Hit any key to start from CD.." before the timer expires.
Mar 11, 2009 | Dell Dimension 4550 PC Desktop
Albatron GeForce MX4000 EL, (64 MB) Graphic Card Logo
110 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
