Question about Cuisinart DGB-500 Coffee Maker
Cuisinart DBG-500 has - -- on display and won't work
Yesterday this happend and after unplugging it for an hour the time started to flash again which indicated it was working. Today nothing on the - -- on the display and none of the buttons work. Could it have bitten the dust only after 5 months? Any ideas that I am missing on how to fix this problem?
  • 8,596 Answers
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
The cleaning button keeps flashing after cleaning. I have cleaned this with water & vinegar several times, but can only make one or two pots of coffee before the cleaning button begins to flash again....
We have this problem as well. We simply clean it as directed once or twice with the vinegar and water mix and then unplug for an hour. This resets our machine for several weeks. Based on the number of comments I've seen on this issue, it seems that the "off" sensor doesn't work.
Oct 10, 2009 | Cuisinart DCC-1200 Coffee Maker
How do I set the time on cuisinart coffee maker model cbc-00? Regular time 12 hour intervals Thank You
Set the function knob to CLOCK
Press and hold the HR button for a few seconds if the clock display time is not flashing
Once display time is flashing:
Press and release the HR button a few times for it to advance - it will say "PM" on the display if it is set for PM
Press and release the MIN button to set the mins
Sep 12, 2009 | Cuisinart DCC-1200 Coffee Maker
My Cuisinart coffee maker won't program start time.
Reset the coffeemaker by unplugging it for 20 minutes or longer - don't skimp on the time left unplugged.
Then plug the coffeemaker back in, reset the normal clock. Remember: It will display PM if it is on PM, but nothing if it is on AM.
Then hit the Program button. Hold in the "Hours" button for a few seconds and set the time you want the coffeemaker to go off in the morning. Hold in the "Minutes" button for a few seconds and change the minutes. Then hit the Program button again.
Now turn your coffeemaker to AUTO-ON - it will now go off at the set time.
Here is a link to the manual:
http://www.cuisinart.com/share/man/30_man.pdf
-Tha Mp3 Doctor
Mar 18, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart DBG-500 has - -- on screen won't do anything
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke dwn - you wouldn't be upset if your $15 Mr. Coffee broke eveyr year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Dec 15, 2008 | Cuisinart DGB-500 Coffee Maker
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a new cuisinart coffee maker and no book came with it. I need to know how to program the coffee maker.
  1. Setting the time
  • When the machine is plugged in, the screen will display 12:00.
  • Press and hold the "HR" and "MIN" button until the numbers flash.
  • Then press the "HR and "MIN" button to scroll through the numbers. When the numbers stop flashing, the time has been set.
CAUTION! When you pass the number 12, the letters "PM" appear to indicate the time between 12 noon and 12 midnight. When these letters do not appear, the time corresponds to the morning hours, from midnight to noon. Always make sure the hour is set according to the correct period so that programming is correct.
  • 2 Programming the start time
  • Press and hold the "PROG" button. The numbers and the indicator light flash.
  • Press "HR" and "MIN" in the same way to set the hour to the desired start time for the cycle. When the numbers stop flashing, the programmed time is set.
CAUTION! Programming the start time is not possible when the coffee maker is running.
Hope this will help you.
Best regards
/Mirran
Aug 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
CAN NOT GET TIMER TO SAY A.M.
I did call Cuisinart and they told me to unplug the unit for at least a half hour. I did unplug it for an hour and then attemptedd to reset the clock and a program. It worked. Evidently, it becomes confused if you try too many attempts.
Feb 14, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-500 Coffee Maker Logo
204 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
