Question about Amana Heating & Cooling
I have a amana pbh092b12mb 26" TTW 9K BTU Heat pump. i know it's cold outside (19 degress) but it just doesn't seem to work right. blows cooler air then warm. what can I check to make sure it is doing everything it should. first winter t use it.
  • bigsteveskb Dec 15, 2008
    Thanks for responding to my problem. I did read that in the manuals, and it is supposed to have a electric heater that kicks in when it is to cold. The heat coming from this source just doesn’t seem to be much warmer then surrounding air. It is warm compared to just the Fan though. But how can I check that it is as hot as it can get?
    Problem Solver:
  • 8 Answers
You didn't say what zone you're in but if you're north of southwest missouri you can forget about anything seeming warm below 30 degrees outside i tell all my customers to switch to emergency heat when temp's get below 25 for extended periods of time 2 days - weeks. either way you're at the mercy of the utility company on emergency heat you get hot heat and faster results heat pumps out of the box can only give you what they can generater from outside temperatures 35-55 they work great giving better than 3 to 1 but that falls off drastically when the temperature plunges
Posted on Dec 15, 2008
Replace heating eliment in 26" Amana TTW airconditioner unit ?
it will be the thermal fuse for sure
its a small metal cylinder usualy around the heating element
with two connections
Dec 04, 2014 | Amana Dryers
Were dose the green wire go to my senville 18000 heat pump indoor unit
The green thermostat wire goes to the G on the terminal strip. If it's not a thermostat wire it is a ground wire Should be grounded to the metal case for safety. It does not affect the operation.
Nov 14, 2014 | Senville 18000 BTU Dual Zone Ductless Air...
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
My LG Model LP0910WNRY2 will not get cold even though the compressor turns on
check the outside and see if its blowing cold air out of condensor otherwise low on freon.
Jun 28, 2014 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Is it normal operation for these units to EVER blow out cold air or "nonheated" air when unit is in heat mode?
Yes. Heat pumps have to go into defrost just like a freezer when the temp gets too cold outside. The heat pump will temper the indoor air electric heat.
Apr 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
The last couple of days our heat pump will not cool below 80 degrees even if we set the temp to 65. The unit keeps running. last week the heat pump worked very well. The unit is 10 years old.
Check the outside unit. Feel the larger line to see if it is cold. Is the condensor dirty. If you have a way to measure temp. Take the return air at the filer and the closest grille temp and subtract. It should be between 19 to 23 degress. If not you have a problem. Could be refrigerant or some other problem. Either way you need to get it checked out by a service tech. Ask for free estimate that way you are going to know how much it cost before hand. Rus
Jul 04, 2009 | Heating & Cooling
Heating & Cooling Logo
152 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
